Weird monitor behaviour with printf on IDF 3.0
ajcalderont
Postby ajcalderont » Mon Feb 19, 2018 10:24 pm
Hi, I'm having issues with monitor output with ESP-IDF 3.0 on Windows 10. I'm using a Wemos Lolin32 and an Adafruit HUZZAH32, and with both boards I'm having the same issue. Consider this test program (using cpp):
#include "freertos/task.h"
extern "C" {void app_main(void);}
void app_main(void)
	while(1)
		for(int i = 0; i < 504; i++)
			printf("%.2X ", i%256);
			if((i + 1) % 24 == 0) printf("\n");
		printf("\n\n");
		vTaskDelay(5000 / portTICK_PERIOD_MS);
The output should be two digits hex numbers separated by a space, on a 24x21 array like this:
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 16 17
18 19 1A 1B 1C 1D 1E 1F 20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F
30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40 41 42 43 44 45 46 47
48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F
60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77
78 79 7A 7B 7C 7D 7E 7F 80 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F
90 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3 A4 A5 A6 A7
A8 A9 AA AB AC AD AE AF B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF
C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF D0 D1 D2 D3 D4 D5 D6 D7
D8 D9 DA DB DC DD DE DF E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF
F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE FF 00 01 02 03 04 05 06 07
08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F
20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30 31 32 33 34 35 36 37
38 39 3A 3B 3C 3D 3E 3F 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F
50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 62 63 64 65 66 67
68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F
80 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F 90 91 92 93 94 95 96 97
98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF
B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF C0 C1 C2 C3 C4 C5 C6 C7
C8 C9 CA CB CC CD CE CF D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF F0 F1 F2 F3 F4 F5 F6 F7
But monitor randomly adds an extra digit or space to some of the numbers, like this (extra space after 05, extra space after 4F, 334 instead of 34):
20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30 31 32 33 334 35 36 37
Anyone else having this problem?
Angus
Re: Weird monitor behaviour with printf on IDF 3.0
Postby Angus » Tue Feb 20, 2018 1:25 am
I may know what this is. For some reason, after the Fall Creators Update Windows 10 idf_monitor.py started sometimes randomly throwing an exception after writing to the "standard output" console. This is the OS telling us the write failed, for whatever reason.
On investigation, people noticed that a subsequent write nearly always succeeded so a kludge was added to retry the write:
https://github.com/espressif/esp-idf/bl ... or.py#L593
I'm not sure anyone verified whether the "failed" write actually appeared on the console. Might explain the doubled-up letters.
If you change around line 597 of idf_monitor.py function (I'm assuming release/v3.0 branch):
                    except IOError:
                        # Windows 10 bug since the Fall Creators Update, sometimes writing to console randomly fails
                        # (but usually succeeds the second time, it seems.) Ref https://github.com/espressif/esp-idf/issues/1136
                        try:
                            self.output.write(b)
                        except IOError:
                            pass
To look like this:
                    except IOError:
                        pass
... does the duplicate output go away?
ajcalderont
Postby ajcalderont » Tue Feb 20, 2018 5:47 am
Hi ESP_Angus, thanks for your reply. This is what I have:
def _output_write(self, data):
            # (but usually succeeds afterwards, it seems.)
            # Ref https://github.com/espressif/esp-idf/issues/1136
            for tries in range(3):
                try:
                    self.output.write(data)
                    return
                except IOError:
                    pass
What should I change?
ajcalderont
Postby ajcalderont » Tue Feb 20, 2018 6:00 am
Hi again ESP_Angus, I just tried without the "for", like this:
            #for tries in range(3):
            try:
				return
            except IOError:
				pass
And now is working, without repeated spaces or characters. Thank you very much!
Angus
Postby Angus » Tue Feb 20, 2018 8:26 pm
Thanks for confirming this. Will put a proper fix into IDF ASAP.
