flashing ESP-WROOM-02D-N4
Posted: Fri Feb 13, 2026 12:14 pm
Hi, tried to use HTTP specific command in ESP-WROOM-02D-N4
getting below responses
AT+GMR
AT version:1.7.3.0(Mar 19 2020 18:15:04)
SDK version:3.0.3(8427744)
compile time:Mar 24 2020 16:16:12
Bin version(Wroom 02):3.0.3
OK
CMD:
AT+HTTPCLIENT=3,0,”http://httpbin.org/post”,"httpbin.org", ... ld2=value2"
Response:
ERROR
Do we have support for httpclient command with ESP8266?
tried to upgrade the AT instruction set by flashing the module using After flashing ver ESP-WROOM-02-AT-V2.2.1.0 and ESP-WROOM-02-AT-V2.2.2.0
with following settings
--flash_mode dio --flash_freq 80m --flash_size 2MB 0x8000 partition_table/partition-table.bin 0x9000 ota_data_initial.bin 0x0 bootloader/bootloader.bin 0x10000 esp-at.bin 0xF0000 at_customize.bin 0xFC000 customized_partitions/client_ca.bin 0x106000 customized_partitions/mqtt_key.bin 0x104000 customized_partitions/mqtt_cert.bin 0x108000 customized_partitions/mqtt_ca.bin 0xF1000 customized_partitions/factory_param.bin 0xF8000 customized_partitions/client_cert.bin 0xFA000 customized_partitions/client_key.bin
ets Jan 8 2013,rst cause:1, boot mode:(3,6)
load 0x40100000, len 6960, room 16
tail 0
chksum 0x4f
load 0x3ffe8008, len 24, room 8
tail 0
chksum 0xc6
load 0x3ffe8020, len 3196, room 8
tail 4
chksum 0x3a
csum 0x3a
<0>
sometimes it gives boot mode:(3,4) or boot mode:(3,7)
Let me know,
1. Do we have seperate bin files for ESP-WROOM-02D-N4, as download available is for only 2MB flash version
2. Does these bin files work with 4MB flash, is their any changes required in address?
waiing for reply
Regards,
AT+GMR
OK
CMD:
Response:
ERROR
tail 0
chksum 0x4f
tail 0
chksum 0xc6
tail 4
chksum 0x3a
csum 0x3a
<0>
Let me know,
waiing for reply
Regards,
