Make Warning at C:/Espressif/frameworks/esp-idf-v5.5/tools/cmake/gdbinit.cmake:52 (message):
Error while generating esp_rom gdbinit
C:/Espressif/frameworks/esp-idf-v5.5/tools/cmake/project.cmake:356 (__generate_gdbinit)
C:/Espressif/frameworks/esp-idf-v5.5/tools/cmake/project.cmake:975 (__project_info)
CMakeLists.txt:8 (project)
A fatal error occurred: bootloader/bootloader.bin requires chip revision in range [v3.1 - v3.99] (this chip is revision v1.3). Use --force to flash anyway.
CMake Error at run_serial_tool.cmake:67 (message):
C:/Espressif/python_env/idf5.5_py3.11_env/Scripts/python.exe;;C:/Espressif/frameworks/esp-idf-v5.5/components/esptool_py/esptool/esptool.py;--chip;esp32p4
failed.
使用online方式自动安装的工具链,在Espressif-IDE中创建新项目,复制example中的hello world例程。编译正常,但按run就会出错,试了V5.5.3和V5.5版本的IDF都一样。
ESP32-P4提示芯片版本不支持怎么?
Re: ESP32-P4提示芯片版本不支持怎么?
esp-idf-tools-setup-online-2.4.1,就用这个安装所有的工具,打开Espressif-IDE,复制例程hello world,都下载不了。 发布时没试吗?
