Lvgl custom external malloc implementation / linking
Posted: Thu Mar 19, 2026 1:24 am
by Baldhead
What do you want to achieve ?
I want to create custom functions for Lvgl memory allocator and that compilation and linking work.
What have you tried so far ?
I downloaded Lvgl from “ESP Component Registry”.
In esp-idf menuconfig, inside Lvgl component config , i select the option “implement the function externally” in “Malloc functions source”.
I created the malloc families functions inside my components folder in my project folder.
C:\esp32-Proj\proj\components\lv_mem_custom_alloc\src\include\lv_mem_custom_alloc.h
C:\esp32-Proj\proj\components\lv_mem_custom_alloc\src\lv_mem_custom_alloc.c
C:\esp32-Proj\proj\components\lv_mem_custom_alloc\CMakeLists.txt
Lvgl folder stay located in managed_components folder inside my project folder.
C:\esp32-Proj\proj\managed_components\lvgl__lvgl
I tried using inline functions too in a .h file, but no luck.
When compiling project, at linker stage, the linker show undefined reference to.
Doubts
How do I get lvgl to recognize(link) my components folder (subfolder inside components folder) ?
What are all the functions that need to be defined, which ones are mandatory, and how do I define / write mem_init() if needed ?
There’s a memory_init() function that I’m not sure it is necessary. I think only malloc(), realloc() and free() would be needed, but it seems I need to define other functions as well.
Is there any documentation on how to do this ?
Code to reproduce
lv_mem_custom_alloc.h file:
void* lv_malloc_core(size_t size);
void* lv_realloc_core(void* ptr, size_t size);
void lv_free_core(void* ptr);
lv_mem_custom_alloc.c file:
    return heap_caps_malloc_prefer(size, 2, MALLOC_CAP_INTERNAL | MALLOC_CAP_8BIT, MALLOC_CAP_SPIRAM);
    return heap_caps_realloc_prefer(ptr, size, 2, MALLOC_CAP_INTERNAL | MALLOC_CAP_8BIT, MALLOC_CAP_SPIRAM);
    heap_caps_free(ptr);
Environment
ESP32-S3
ESP-IDF 5.5.3 with visual studio code
LVGL 9.4.0
Custom board.
Notes:
* The project is running (without custom memory allocator), but sometimes, i think, that “normal” allocator cannot allocate memory, and the system crash or the task running lvgl crash.
* https://forum.lvgl.io/t/how-to-implemen ... -idf/23723
Re: Lvgl custom external malloc implementation / linking
Posted: Thu Mar 19, 2026 10:36 pm
by Baldhead
Some suggestion ?
Posted: Thu Mar 19, 2026 11:34 pm
by MicroController
Function implementations to link need (only) be available at link time of the application. So if any part of your application declares some dependency to your implementations, i.e. REQUIRES lv_mem_custom_alloc,, they should be built and available at link time.
Not sure about how to 'cleanly' make lvgl include your functions' declarations without touching the managed_components though.
Posted: Fri Mar 20, 2026 1:53 am
by Baldhead
It seems that this solved it (It compiled and linked, but I haven't tested it on the hardware yet).
Necessary functions (only .c file, the function interface(.h file), the lvgl library already provides):
lv_malloc_core()
lv_realloc_core()
lv_free_core()
lv_mem_init()
Optional functions (only .c file, the function interface(.h file), the lvgl library already provides):
lv_mem_monitor_core() // I left a comment in my source code.
lv_mem_test_core() // I left a comment in my source code.
Note:
lv_mem_init() only needs to be declared empty for compilation, since heap initialization is provided by esp-idf.
I don't know if all the steps below are necessary, but this is how it worked.
1. In your component's CMakeLists.txt file (the one containing the memory functions), add:
2. Define Visibility as INTERFACE
If your component provides the functions that LVGL uses, it needs to export those definitions. In your component's CMakeLists.txt file under components:
idf_component_register(
SRCS "your_memory.c"
INCLUDE_DIRS "include"
# Forces the linker to include all the functions of this component.
# even if no one explicitly calls them in the main
WHOLE_ARCHIVE // I only added this to my idf_component_register because the rest I already had.
# This tells CMake: "Whoever uses me (or whoever the system links to)
# It needs to be linked to my memory functions.
target_link_libraries(${COMPONENT_LIB} INTERFACE "-u lv_malloc_core")
target_link_libraries(${COMPONENT_LIB} INTERFACE "-u lv_realloc_core")
target_link_libraries(${COMPONENT_LIB} INTERFACE "-u lv_free_core")
#target_link_libraries(${COMPONENT_LIB} INTERFACE "-u lv_mem_monitor_core") // comment out
#target_link_libraries(${COMPONENT_LIB} INTERFACE "-u lv_mem_test_core") // comment out
3. Linking Order
ESP-IDF links components in the order they appear. If LVGL requests malloc_custom and your component hasn't yet been "seen" by the linker, it will throw an error.
Add the following to the CMakeLists.txt file at the project root.
# It forces the linker to process its memory component before LVGL.
idf_build_set_property(LINK_COMPONENTS "lv_mem_custom_alloc" APPEND)
