ESP32-S3 Issue with enabling RPA using NimBLE
Posted: Wed Mar 25, 2026 6:26 pm
I am currently running a heavily modified cts_cent example. I am able to connect and bond with the target device and exchange IRK.
Now, I need to enable RPA to perform the connections. So far, I was able to connect using a Random Static address, but never as Resolvable Private address. The documentation seems to point to functions that are only applicable to Host Based Privacy. However, ESP32-S3 uses Controller Based Privacy, which causes several functions at "ble_hs_pvcy.h" to become unavailable.
I have tried calling several function combinations, but to no avail.
Currently, I have the following relevant lines of code:
Then, on the connect function, I have the following:
Furthermore, I see ble_gap_connect() being called with own_addr_type = 0x03, which is what I expect it to be (BLE_OWN_ADDR_RPA_RANDOM_DEFAULT), however using a BLE sniffer i see the address as Static instead of Resolvable.
Thanks in advance
ble_hs_cfg.sm_our_key_dist = BLE_SM_PAIR_KEY_DIST_ID | BLE_SM_PAIR_KEY_DIST_ENC | BLE_SM_PAIR_KEY_DIST_SIGN;
ble_hs_cfg.sm_their_key_dist = BLE_SM_PAIR_KEY_DIST_ENC | BLE_SM_PAIR_KEY_DIST_SIGN;Code: Select all
static void
ble_cts_cent_on_sync(void)
int rc;
// Enable RPA capability
rc = ble_hs_pvcy_set_resolve_enabled(true);
assert(rc == 0);
// Generate Random Static Address
ble_addr_t out_addr = {
.type = BLE_ADDR_PUBLIC,
.val = {0},
ble_hs_id_gen_rnd(0, &out_addr);
ble_hs_id_set_rnd(out_addr.val);
// Configure the ESP with a Bluetooth MAC Address
rc = ble_hs_util_ensure_addr(1);
assert(rc == 0);
/* Begin scanning for a peripheral to connect to. */
ble_cts_cent_scan();
}Code: Select all
static void
ble_cts_cent_connect_if_interesting(void *disc)
uint8_t own_addr_type;
int rc = 0;
ble_addr_t *addr;
/* Scanning must be stopped before a connection can be initiated. */
rc = ble_gap_disc_cancel();
/* Figure out address to use while connecting*/
rc = ble_hs_id_infer_auto(1, &own_addr_type);
printf("\nAddress type: %d\n", own_addr_type);
if (rc != 0)
printf("\n\nError determining address type; rc=%d\n", rc);
return;
/* Try to connect the the advertiser. Allow 30 seconds (30000 ms) for
* timeout.
addr = &((struct ble_gap_disc_desc *)disc)->addr;
// Set connection parameters to T4H default values
struct ble_gap_conn_params params = {
.scan_itvl = 0x0010,
.scan_window = 0x0010,
.itvl_max = 8,
.itvl_min = 8,
.latency = 49,
.supervision_timeout = 300,
.min_ce_len = BLE_GAP_INITIAL_CONN_MIN_CE_LEN,
.max_ce_len = BLE_GAP_INITIAL_CONN_MAX_CE_LEN,
rc = ble_gap_connect(own_addr_type, addr, 30000, ¶ms,
ble_cts_cent_gap_event, NULL);
if (rc != 0)
printf("\n\nError: Failed to connect to device; addr_type=%d "
"addr=%s; rc=%d\n",
addr->type, addr_str(addr->val), rc);
return;
}Thanks in advance
