Will ESP32-P4 revision 1.0 function on a board that is designed for revision 3.0+?
Posted: Mon Apr 06, 2026 4:48 pm
by greengnu
the hardware design guidelines https://docs.espressif.com/projects/esp ... p32p4.html show two different reference schematics for chip revisions >=3.0 and for chip revisions <3.0
If I'm not mistaken the only differences are
1. pre 3.0 version has the DCDC components R1, R2 and C2 unpopulated, while 3.0+ version uses two 499k resistors and a 22pF capacitor
2. pre 3.0 version has pin 54 as NC, while 3.0+ version have the DCDC output supplied to pin 54.
the pre 3.0 schematic https://docs.espressif.com/projects/esp ... d-v1.3.png states:
IMPORTANT: Please do not mount R1, R2 and C2 by default.
My questions are:
1. how important is it that R1, R2 and C2 are not populated on a PCB with a pre 3.0 P4 chip? is it rather of "your chip will not run at optimal efficiency" importance, or is it more like "you will brick your P4 if you do" importance?
2. Is it ok to connect DCDC output to Pin 54 even on pre 3.0 chips since it is not connected internally, or will doing so damage the P4?
