How To Reduce Time Between SPI Transactions
Alextesttech
Postby Alextesttech » Tue Apr 07, 2026 8:13 pm
Hello I am trying to sample a ADS131M06 at 32kHz but I am struggling to get the time between SPI transactions below 30us any suggestions?
#include <stdio.h>
#include "freertos/task.h"
#include "esp_log.h"
#include "ads131m0x.h"
static const char *TAG = "MAIN";
static QueueHandle_t adc_queue = NULL;
// ─── Sampling task ────────────────────────────────────────────────────────────
// Runs on Core 1 at highest priority — just reads the ADC and queues the data.
static void sample_task(void *arg)
    InitADC();
    adc_channel_data result = {0};
    toggleSYNC();
    delay_us(1);
    while (1)
        if (waitForDRDYinterrupt(1000))
            readData(&result);
            xQueueSend(adc_queue, &result, 0);  // non-blocking send
// ─── USB send task ────────────────────────────────────────────────────────────
// Runs on Core 0 — drains the queue and sends binary packets over USB CDC.
static void usb_task(void *arg)
    while (1)
        if (xQueueReceive(adc_queue, &result, portMAX_DELAY))
// ─── App entry point ──────────────────────────────────────────────────────────
void app_main(void)
    adc_queue = xQueueCreate(256, sizeof(adc_channel_data));  // bigger buffer at 32 kHz
    xTaskCreatePinnedToCore(sample_task, "adc_sample", 4096, NULL, configMAX_PRIORITIES - 1, NULL, 1);
    xTaskCreatePinnedToCore(usb_task,"Usb Send",4096,NULL,configMAX_PRIORITIES - 2,NULL,0);
void InitSPI(void)
    /* NOTE: The ADS131M06 operates in SPI mode 1 (CPOL = 0, CPHA = 1). */
    spi_bus_config_t bus_cfg = {
        .mosi_io_num     = PIN_MOSI,
        .miso_io_num     = PIN_MISO,
        .sclk_io_num     = PIN_SCLK,
        .quadwp_io_num   = -1,
        .quadhd_io_num   = -1,
        .max_transfer_sz = 64,  /* Larger than the biggest frame we will ever send */
        //.isr_cpu_id = 1,
    esp_err_t ret = spi_bus_initialize(SPI_HOST_DEVICE, &bus_cfg, SPI_DMA_CH_AUTO);
    if (ret != ESP_OK && ret != ESP_ERR_INVALID_STATE)
        ESP_LOGE(TAG, "spi_bus_initialize failed: %s", esp_err_to_name(ret));
        return;
    spi_device_interface_config_t dev_cfg = {
        .clock_speed_hz = SPI_CLOCK_HZ,
        .mode           = 1,            /* CPOL=0, CPHA=1 */
        .spics_io_num   = PIN_CS,
        .queue_size     = 2,
        .flags          = SPI_DEVICE_NO_DUMMY,
        //.input_delay_ns = 1,
        .cs_ena_pretrans = 1,
        //.cs_ena_posttrans = 2,
        .clock_source = SPI_CLK_SRC_XTAL,
    ret = spi_bus_add_device(SPI_HOST_DEVICE, &dev_cfg, &s_spi);
    if (ret != ESP_OK)
        ESP_LOGE(TAG, "spi_bus_add_device failed: %s", esp_err_to_name(ret));
void spiSendReceiveArrays(const uint8_t dataTx[], uint8_t dataRx[], const uint8_t byteLength)
    assert(dataTx && dataRx);
    //spi_device_acquire_bus(s_spi,portMAX_DELAY);
    t.length = (size_t) byteLength * 8;
    t.tx_buffer = dataTx;
    t.rx_buffer = dataRx;
    spi_device_polling_transmit(s_spi, &t);
    //spi_device_release_bus(s_spi);
bool readData(adc_channel_data *DataStruct)
    int i;
    uint8_t crcTx[4]                        = { 0 };
    uint8_t dataTx[24] = { 0 };
    uint8_t dataRx[24] = { 0 };
    uint8_t bytesPerWord                    = getWordByteLength();
#ifdef ENABLE_CRC_IN
    // Build CRC word (only if "RX_CRC_EN" register bit is enabled)
    uint16_t crcWordIn = calculateCRC(&DataTx[0], bytesPerWord * 2, 0xFFFF);
    crcTx[0] = upperByte(crcWordIn);
    crcTx[1] = lowerByte(crcWordIn);
#endif
    /* Set the nCS pin LOW */
    //setCS(LOW);
    // Send NULL word, receive response word
    uint16_t opcodes[7] = {0};
    opcodes[0] = OPCODE_NULL;
    uint8_t numberOfBytes = buildSPIarray(opcodes, 7, dataTx);
    // Send the opcode (and crc word, if enabled)
        spiSendReceiveArrays(dataTx,dataRx,numberOfBytes);
    DataStruct->response = combineBytes(dataRx[0], dataRx[1]);
    // (OPTIONAL) Do something with the response (STATUS) word.
    // ...Here we only use the response for calculating the CRC-OUT
    //uint16_t crcWord = calculateCRC(&dataRx[0], bytesPerWord, 0xFFFF);
    // (OPTIONAL) Ignore CRC error checking
    uint16_t crcWord = 0;
    DataStruct->channel0 = signExtend(&dataRx[3]);
#if (CHANNEL_COUNT > 1)
    DataStruct->channel1 = signExtend(&dataRx[6]);
#endif
#if (CHANNEL_COUNT > 2)
    DataStruct->channel2 = signExtend(&dataRx[9]);
#endif
#if (CHANNEL_COUNT > 3)
    DataStruct->channel3 = signExtend(&dataRx[12]);
#endif
#if (CHANNEL_COUNT > 4)
    DataStruct->channel4 = signExtend(&dataRx[15]);
#endif
#if (CHANNEL_COUNT > 5)
    DataStruct->channel5 = signExtend(&dataRx[18]);
#endif
#if (CHANNEL_COUNT > 6)
    DataStruct->channel6 = signExtend(&dataRx[21]);
#endif
#if (CHANNEL_COUNT > 7)
    DataStruct->channel7 = signExtend(&dataRx[24]);
#endif
    uint8_t crcOffset = (CHANNEL_COUNT + 1) * bytesPerWord;
    DataStruct->crc = combineBytes(dataRx[crcOffset], dataRx[crcOffset + 1]);
    /* NOTE: If we continue calculating the CRC with a matching CRC, the result should be zero.
     * Any non-zero result will indicate a mismatch.
    //crcWord = calculateCRC(&dataRx[0], bytesPerWord, crcWord);
    /* Set the nCS pin HIGH */
    //setCS(HIGH);
    // Returns true when a CRC error occurs
    return ((bool) crcWord);
SPI logic analyzer capture.jpg (305.99 KiB) Viewed 115 times
MicroController
Re: How To Reduce Time Between SPI Transactions
Postby MicroController » Thu Apr 09, 2026 3:29 pm
How many channels are you reading? I.e. what's your frame size/rate?
Doesn't look like this should be done repeatedly before every transaction.
Handling one transaction's results can also be done concurrently with the next transaction running (double-buffering), either in another task or just by interleaving like
waitForDRDYinterrupt(1000);
spi_device_polling_start(s_spi, &trans_1);
while(1) {
  spi_device_polling_end(s_spi,1);
  // <- Prepare next trans_2 here.
  spi_device_polling_start(s_spi, &trans_2)
  // trans_2 is running; extract and pass on data from transaction 1...
  // <- Prepare next trans_1 here.
  // trans_1 is running; extract and pass on data from transaction 2...
Alextesttech
Postby Alextesttech » Thu Apr 09, 2026 5:48 pm
Six channels, a frame is 8 words, each word is 24bits so 192 bits at a clock speed of 20Mhz.
After looking at my code thinking about it I came to the conclusion that i needed to separate the actual transaction of data and processing, which is along the lines of what you were suggesting here
while(1) {
I will rewrite and report back.
Alextesttech
Postby Alextesttech » Fri Apr 10, 2026 12:45 pm
I rewrote the read function to be simpler:
    spiSendReceiveArrays(testtx,testrx,24);
    return true;
this reduced the time to ~22.4us between transactions.
I have been informed that the hardware will now require two of the ADS131M06 parts.
Would it be worth while to manually control the CS lines for each of the ADCs or just set up a new SPI device interface Config ?
SPI logic analyzer capture.jpg (364.71 KiB) Viewed 54 times
MicroController
Postby MicroController » Mon Apr 13, 2026 3:32 pm
Would it be worth while to manually control the CS lines for each of the ADCs ... ?
I'd say no.
But the "double-buffering" approach from above may make even more sense with two ADCs.
If the ADCs don't share a common clock source, you'll also have to expect the clocks to slightly drift relative to one another; one ADC might produce more samples per second than the other, so reading them out in sync may become a bit more complicated.
Users browsing this forum: ChatGPT-User, Semrush [Bot] and 4 guests
