Emergency stop of RMT
Posted: Wed Apr 15, 2026 9:33 am
Hello! I'm using ESP-IDF v5.5.1 and an ESP32 board to control a stepper motor using the RMT module, following the example from:
https://github.com/espressif/esp-idf/bl ... ple_main.c
How to properly and urgently stop RMT during command execution in ESP-IDF v5.5.1?
For example, an acceleration command is sent to RMT and the execution of this command is awaited:
But during the acceleration, the rotation limit is reached (e.g., a stepper motor rotary platform enters the optocoupler zone), and a pin interrupt fires, indicating that the movement must be stopped immediately.
The approach of disabling and re-enabling RMT
does not work — everything freezes while waiting for the operation to complete. Register access as shown here: https://github.com/espressif/esp-idf/issues/1456 is disabled in ESP-IDF v5.5.1.
My initialization RMT:
ESP_ERROR_CHECK(rmt_transmit(motor_chan, accel_motor_encoder, &steps, sizeof(uint32_t), &tx_config));
ESP_ERROR_CHECK(rmt_tx_wait_all_done(motor_chan, portMAX_DELAY));
rmt_disable(motor_chan);
vTaskDelay(pdMS_TO_TICKS(50));
rmt_enable(motor_chan);
#define STEP_MOTOR_RESOLUTION_HZ 1000000
#define SAMPLE_POINTS_ACDEC 300
#define LOW_FREQ_HZ 50
#define MAIN_FREQ_HZ 1000
#define SYMBOL_DURATION ((uint32_t)(STEP_MOTOR_RESOLUTION_HZ / MAIN_FREQ_HZ / 2))
#define BLOCK_SIZE 4000
rmt_channel_handle_t motor_chan = NULL;
rmt_encoder_handle_t accel_motor_encoder = NULL;
rmt_encoder_handle_t decel_motor_encoder = NULL;
rmt_encoder_handle_t uniform_motor_encoder = NULL;
rmt_encoder_handle_t copy_encoder = NULL;
rmt_copy_encoder_config_t copy_encoder_config_t = {};
static stepper_motor_curve_encoder_config_t decel_encoder_config = {
.resolution = STEP_MOTOR_RESOLUTION_HZ,
.sample_points = SAMPLE_POINTS_ACDEC,
.start_freq_hz = MAIN_FREQ_HZ,
.end_freq_hz = LOW_FREQ_HZ,
static stepper_motor_uniform_encoder_config_t uniform_encoder_config = {
static stepper_motor_curve_encoder_config_t accel_encoder_config = {
.start_freq_hz = LOW_FREQ_HZ,
.end_freq_hz = MAIN_FREQ_HZ,
ESP_LOGI(TAG_RMT, "Create RMT TX channel");
rmt_tx_channel_config_t tx_chan_config = {
.clk_src = RMT_CLK_SRC_DEFAULT,
.gpio_num = STEP_MOTOR,
.mem_block_symbols = 64,
.resolution_hz = STEP_MOTOR_RESOLUTION_HZ,
.trans_queue_depth = 10,
ESP_ERROR_CHECK(rmt_new_tx_channel(&tx_chan_config, &motor_chan));
ESP_LOGI(TAG_RMT, "Create motor encoders");
ESP_ERROR_CHECK(rmt_new_copy_encoder(©_encoder_config_t, ©_encoder));
ESP_ERROR_CHECK(rmt_new_stepper_motor_curve_encoder(&accel_encoder_config, &accel_motor_encoder));
ESP_ERROR_CHECK(rmt_new_stepper_motor_uniform_encoder(&uniform_encoder_config, &uniform_motor_encoder));
ESP_ERROR_CHECK(rmt_new_stepper_motor_curve_encoder(&decel_encoder_config, &decel_motor_encoder));
ESP_LOGI(TAG_RMT, "Enable RMT channel");
ESP_ERROR_CHECK(rmt_enable(motor_chan));
