Reliable command delivery to ESP32‑H2 Zigbee sleepy end device (ZHA)
Posted: Fri May 15, 2026 7:51 am
Hi all,
I’m building a battery-powered Zigbee door lock using an ESP32‑H2 (Arduino Zigbee) and running it through Home Assistant (ZHA + SkyConnect).
The core issue I’m facing is that commands sent from Home Assistant are only executed if the device happens to be awake at the exact moment of sending, and I have not found a way to make command delivery reliable for a sleeping device.
I’ve tried several approaches (polling, wake signals, delayed commands, etc.), but all of them run into what seems like a fundamental limitation in how ZHA and sleepy Zigbee devices interact.
I’m now trying to determine whether: this is an inherent limitation or if I’m missing a known design pattern
Setup
ESP32‑H2 (battery-powered)
Zigbee end device (not a router)
Arduino Zigbee (not ESP‑IDF)
Exposed as a simple On/Off device (ZigbeeLight)
Controls a DC motor to lock/unlock
Uses deep sleep for battery life
Wake sources:
External button (manual wake)
Periodic timer (polling)
Coordinator:
Home Assistant ZHA
SkyConnect (ZBT‑1)
Intended behavior
The goal is a typical smart lock workflow:
Send lock/unlock command from Home Assistant at any time
Device wakes periodically or on demand
Command is delivered reliably
Motor executes
Device goes back to sleep
Actual behavior
If the device is asleep → HA attempts command for ~30 s → times out
If I wake the device after sending the command → nothing happens
Repeating commands → sometimes works, often does not
HA does not queue or retry commands after failure
Availability state does not properly reflect wake cycles
What I have tried
1. Periodic polling
Wake every ~10 s
Short active window
→ Commands sometimes succeed, but not reliably
Behavior is clearly timing-dependent
2. Availability-based logic
Tried triggering automations on device availability
Found that:
Availability does not change for short wake cycles
Device often remains unavailable
→ Not usable as a wake indicator
3. “Send then wake”
Send command from HA
Then manually wake the device
→ Does not work
The command has already been discarded by HA
4. Binary sensor “wake beacon”
Device reports “awake” via Zigbee
HA waits for signal before sending command
→ Not reliable
HA automation processing is not synchronized with Zigbee delivery
5. Enforced awake window (device stays awake several seconds)
Keep device awake ~3–5 seconds after wake
→ Leads to instability in Arduino Zigbee
erratic serial output
broken behavior
Suggests the Arduino Zigbee stack is not designed for this pattern
Observations / conclusions so far
Based on testing:
HA/ZHA requires confirmed delivery (ACK) before updating state
Commands are not queued for later execution
Availability is not a reliable wake signal
Command delivery depends on tight timing overlap
Arduino Zigbee provides limited control over message timing
This results in unavoidable race conditions when the device is asleep.
My question
Is reliable command delivery to a battery-powered Zigbee end device possible in ZHA without implementing Poll Control (cluster 0x0020)?
More specifically:
Is this fundamentally how ZHA handles sleepy devices?
Is Arduino Zigbee too limited for this type of device?
Has anyone successfully built a battery-powered Zigbee actuator (e.g., lock) that:
is not always on
and does not implement Poll Control?
Possible next steps I’m considering
Switching to ESP‑IDF Zigbee to implement Poll Control properly
Trying Zigbee2MQTT to compare behavior
Keeping the device awake longer (but concerns about stability remain)
Moving away from sleepy device design
Looking for
Confirmation if this is a hard limitation
Known design patterns for Zigbee locks
Experiences from others working with:
ESP32‑H2 Zigbee
sleepy actuators (not just sensors)
ZHA limitations and behavior
Setup
Wake sources:
Coordinator:
Home Assistant ZHA
SkyConnect (ZBT‑1)
Intended behavior
Motor executes
Actual behavior
What I have tried
1. Periodic polling
Wake every ~10 s
Short active window
Found that:
3. “Send then wake”
→ Does not work
→ Not reliable
broken behavior
Based on testing:
My question
More specifically:
is not always on
Looking for
ESP32‑H2 Zigbee
