I want to run the ESP-Vocat program (code) using Visual Studio Code and then flash it to the ESP-Vocat via Type-C.
Posted: Thu May 28, 2026 2:09 am
by cat7546ai
I want to run the ESP-Vocat program (code) using Visual Studio Code and then flash it to the ESP-Vocat via Type-C. Since the ESP-Vocat program (code) is extensive, how should I do it? Which program (code) should I start running? Please tell me the detailed steps. Thank you.
Re: I want to run the ESP-Vocat program (code) using Visual Studio Code and then flash it to the ESP-Vocat via Type-C.
Posted: Thu May 28, 2026 2:26 am
by Sprite
As the
page for this devkit states, it uses the Brookesia projects for its examples, so I'd suggest you look
there for more info.
Posted: Fri May 29, 2026 5:32 am
by cat7546ai
thank you very much.
Posted: Fri May 29, 2026 5:34 am
by cat7546ai
