## Summary
Building a Matter commissioner on `ESP-Thread-Border-Router-Board v1.x`
(ESP32-S3 + ESP32-H2 RCP) using `esp-matter examples/controller` as a base.
Commissioning works fine with my own `floor3-DK` Thermostat (nRF54L15
running connectedhomeip 1.5 / OpenThread, ICD/Thread). It **fails
deterministically** with two third-party Matter-over-Thread devices:
1. **Aqara Climate Sensor W100** (VID `0x115F`, PID `0x2004`) —
the same family as in [#1532](https://github.com/espressif/esp-matter/issues/1532).
2. **IKEA Timmerflotte** Thermometer (same family as reported by
`xbln` in [#1532, 2026-05-10](https://github.com/espressif/esp-matter ... uecomment-…)).
The exact same pair codes commission successfully on a Linux BlueZ host
running `chip-tool pairing code-thread --bypass-attestation-verifier 1`.
After the failed MTU exchange the ESP32-S3 crashes with `Guru Meditation
Error: Core 0 panic'ed (LoadProhibited)` and reboots.
## Toolchain / Setup
| Component | Version |
| Hardware | ESP-Thread-Border-Router-Board (ESP32-S3 + ESP32-H2 RCP) |
| ESP-IDF | `v5.4.4` |
| esp-matter | `release/v1.5` @ `92a7abe5` (2026-05-22) |
| connectedhomeip | `cf84d0360c` (2025-12-09) — includes [PR #40733 multi-UUID16 scanner fix] |
| Example base | `examples/controller` |
| Floor4 patches | `ChipDeviceScanner.cpp: passive=0` (active scan), `CHIP_SHELL_MAX_LINE_SIZE 512`, `CONFIG_BT_NIMBLE_ENABLE_CONN_REATTEMPT=n` |
Relevant sdkconfig overrides:
# OTBR board: 8 MB flash
CONFIG_ESPTOOLPY_FLASHSIZE_4MB=n
CONFIG_ESPTOOLPY_FLASHSIZE_8MB=y
# CSL transmitter for ICD child support (Stage 2 / Stufe 2 in our project)
CONFIG_OPENTHREAD_CSL_ENABLE=y
CONFIG_OPENTHREAD_MLE_MAX_CHILDREN=16
# Stage 3a: try to avoid reconnect race against chip-stack
Plus the `sdkconfig.defaults.otbr` from `examples/controller` (BLE
+ WiFi + OpenThread BR enabled, `partitions_br.csv`,
`LWIP_IPV6_NUM_ADDRESSES=12`).
Floor4 application code calls `pairing_command::pairing_code_thread()`
via a small HTTP API. We add a `DeviceAttestationDelegate` to bypass
attestation verification for Aqara (whose PAA is not in the default
trust store):
```cpp
class TrustingAttestationDelegate : public chip::Credentials::DeviceAttestationDelegate {
chip::Optional<uint16_t> FailSafeExpiryTimeoutSecs() const override { return chip::NullOptional; }
void OnDeviceAttestationCompleted(
chip::Controller::DeviceCommissioner *cmsnr, chip::DeviceProxy *device,
const chip::Credentials::DeviceAttestationVerifier::AttestationDeviceInfo &info,
chip::Credentials::AttestationVerificationResult result) override {
cmsnr->ContinueCommissioningAfterDeviceAttestation(
device, chip::Credentials::AttestationVerificationResult::kSuccess);
bool ShouldWaitAfterDeviceAttestation() override { return false; }
The pair is invoked via:
```cpp
CommissioningParameters params =
CommissioningParameters().SetThreadOperationalDataset(dataset_span);
params.SetDeviceAttestationDelegate(&s_attestation_delegate);
commissioner->RegisterPairingDelegate(&pairing_command::get_instance());
commissioner->PairDevice(node_id, payload, params, DiscoveryType::kAll);
## Reproduction A — Aqara W100 (esp-matter v1.5, both PR #40733 and CONN_REATTEMPT=n active)
User triggers Aqara into commissioning advertisement, then:
I [floor4] commission node=3679816925 code=03679816925 (BLE-Thread, dataset=111 B)
I chip[CTL]: Starting commissionable node discovery over BLE
I NimBLE: GAP procedure initiated: discovery;
I NimBLE: own_addr_type=1 filter_policy=0 passive=0 limited=0 filter_duplicates=1
I NimBLE: duration=60000ms
I chip[BLE]: Device Discriminator match. Attempting to connect
I NimBLE: GAP procedure initiated: connect;
I NimBLE: peer_addr=d4:61:fc:03:c2:86
I NimBLE: scan_itvl=16 scan_window=16 itvl_min=24 itvl_max=40 latency=0 supervision_timeout=256
I NimBLE: GATT procedure initiated: exchange mtu
E chip[DL]: Disabling CHIPoBLE service due to error: ac
I NimBLE: GAP procedure initiated: stop advertising.
I NimBLE: GAP procedure initiated: terminate connection; conn_handle=1 hci_reason=19
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
CHIP error `0xac` = `CHIP_ERROR_INTERNAL`. The connection is then
terminated by the central (us, `hci_reason=19` = "remote user terminated
connection"), and a few hundred ms later the firmware traps in
`LoadProhibited` and reboots.
Compared to esp-matter v1.4.2 (which does **not** include
[PR #40733](https://github.com/project-chip/connect ... pull/40733)),
the Aqara is now discovered correctly thanks to the multi-UUID16
scanner fix — the discriminator match is the new green step. The MTU
phase still fails the same way.
## Reproduction B — IKEA Timmerflotte (esp-matter v1.4.2, same failure as v1.5)
Same flow, different device MAC:
I [floor4] commission node=26320938479 code=26320938479 (BLE-Thread, dataset=111 B)
I NimBLE: peer_addr=dc:d9:ce:c5:a8:7f
Bit-identical failure signature to the Aqara. This matches
`xbln`'s May 2026 comment in #1532.
## Reproduction C — control: works with chip-tool on Linux BlueZ
Same Aqara, same pair code, paired in seconds with:
chip-tool pairing code-thread 5001 hex:<dataset> 03679816925 \
Log excerpt:
[CTL] Starting commissionable node discovery over BLE
[BLE] Device discriminator match. Attempting to connect.
[BLE] New device connected: D0:03:73:6A:93:23
[BLE] subscribe complete, ep = ...
[BLE] peripheral chose BTP version 4; central expected between 4 and 4
[BLE] using BTP fragment sizes rx 244 / tx 244.
[CTL] PASE session established with commissionee.
[CTL] Commissioning complete for node ID 0x0000000000001389: success
So the Aqara/IKEA devices are well-formed; the bug is in the ESP32-S3
NimBLE-based commissioner path, specifically around the GATT MTU
exchange handling, plus an additional unhandled-exception path that
turns a recoverable BLE error into a board reboot.
## Reproduction D — control: same bug in stock `examples/controller`
We re-built the **stock** `esp-matter/examples/controller` example
(no floor4 modifications, only the default `sdkconfig.defaults`,
`sdkconfig.defaults.esp32s3` and `sdkconfig.defaults.otbr`), erased
flash, booted with no WiFi credentials so Wi-Fi STA never associates,
and triggered the pair via the built-in shell:
matter esp controller pairing code-thread 5001 <hex-thread-dataset> 03679816925
(after locally bumping `CHIP_SHELL_MAX_LINE_SIZE` from 256 to 512 so
the long argument line is not truncated). Same NimBLE startup, same
discriminator match (with `passive=0`), same `error: ac`, same crash.
So no Wi-Fi/BLE coexistence interference, no application bug — this
is reproducible on a stock Espressif Matter commissioner example.
## What we'd like to know
1. Has anyone got a working commissioner setup on `ESP-Thread-Border-Router-Board`
that pairs a Matter-over-Thread device whose PAA is **not** in the
default trust store (Aqara `0x115F`, IKEA `0x117C`, Nanoleaf, …)?
2. The error `0xac` (`CHIP_ERROR_INTERNAL`) is raised from
`BLEManagerImpl::HandlePlatformSpecificBLEEvent` after our central
initiated the GATT MTU exchange. What is the expected handler path
on the central side for `BLE_GAP_EVENT_MTU`? In our build it falls
through `default:` in `OnGapEvent()` without setting `err`, yet
`Disabling CHIPoBLE service due to error: ac` is logged — implying
the error originates from a previously-posted event handler that we
have not been able to identify from the source.
3. Beyond [PR #40733](https://github.com/project-chip/connect ... pull/40733)
(already in esp-matter v1.5 via `cf84d0360c`), is there a candidate
patch or branch addressing the MTU-exchange / CHIPoBLE central
commissioning path against Aqara/IKEA-style peripherals? Should we
test ESP-IDF v6.0.1 with a separate esp-matter, or is that
officially unsupported?
4. The `LoadProhibited` crash after the BLE teardown is a separate bug
(the MTU error itself is recoverable in principle). Capturing a
useful backtrace via `idf.py monitor` is tricky because the same
serial line is held by our application; we can re-run with a clean
monitor session if that would help.
Happy to ship a full `sdkconfig`, a `git diff` of our two-line
ChipDeviceScanner patch, the full filtered serial log and a memory
dump on request.
## Appendix: filtered serial transcripts
### A. Aqara on esp-matter v1.5 (full pair attempt + crash, OPENTHREAD RIO noise removed)
I chip[CTL]: Stopping commissionable node discovery over DNS-SD
I chip[CTL]: Skipping commissionable node discovery over Wi-Fi PAF since not supported by the controller!
I chip[CTL]: Skipping commissionable node discovery over NFC since not supported by the controller!
I chip[CTL]: Starting commissionable node discovery over DNS-SD
I NimBLE: peer_addr_type=1 peer_addr=d4:61:fc:03:c2:86
I NimBLE: scan_itvl=16 scan_window=16 itvl_min=24 itvl_max=40 latency=0 supervision_timeout=256 min_ce_len=0 max_ce_len=0 own_addr_type=1
### B. IKEA on esp-matter v1.4.2 (identical signature)
I NimBLE: peer_addr_type=1 peer_addr=dc:d9:ce:c5:a8:7f
### C. chip-tool (Linux BlueZ) on Aqara — same pair code, success
[BLE] BLE removing known devices
[BLE] BLE initiating scan
[BLE] ChipDeviceScanner has started scanning!
[BLE] Device 1C:18:16:4C:8E:E8 does not look like a CHIP device.
[BLE] Device 4E:A1:C5:D5:98:58 does not look like a CHIP device.
[BLE] New device scanned: D0:03:73:6A:93:23
[BLE] ChipDeviceScanner has stopped scanning!
[DL] ConnectDevice complete
[CTL] Discovered device to be commissioned over BLE
[CTL] Attempting PASE connection to BLE
... (PASE Pake1/2/3 success) ...
[CTL] PASE session established with commissionee. Stopping discovery.
[TOO] PASE establishment successful
[CTL] Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
... (AttestationVerification with --bypass, Continue, CASE Sigma1/2/3) ...
[CTL] Received CommissioningComplete response, errorCode=0
### D. Stock `examples/controller` on v1.5 (no application code at all)
Same `error: ac` after GATT MTU exchange. Identical signature. We omit
the boot prelude for brevity; the relevant subset is identical to (A).
Thanks for any pointers!
ESP32 Border Router crashes during commission with Aqara and IKEA device
hanshuckebein
Users browsing this forum: meta-externalagent, Qwantbot and 2 guests
