problem about esp32 spi half duplex
Posted: Wed Jun 03, 2026 2:56 am
### Background
An MCU is connected to the ESP32C3 via SPI (MOSI, MISO, CLK, CS) plus GPIO pins, with the ESP32 half-duplex SPI protocol adopted for communication.
### Phenomenon
I am using the segmented mode of half-duplex SPI. During initialization, 16 buffer buckets are initialized and consecutively enqueued via `spi_slave_hd_queue_trans`. After power-up, the master device first runs two successive transaction sequences consisting of (WRDMA + WR_DONE). Afterwards, the master repeats the identical two rounds of (WRDMA + WR_DONE) transactions again, with test results listed below:
- For the initial two transactions, the slave retrieves valid data consistently every time by calling `spi_slave_hd_get_trans_res`.
- For the subsequent two repeated transactions, the slave obtains incorrect data on the first read via `spi_slave_hd_get_trans_res`, while the second read returns correct data.
Moreover, after the initial batch of transactions, every subsequent continuous (WRDMA + WR_DONE) transaction sequence keeps showing faulty data at the first reception and valid readings from the second transfer onward.
I have failed to pinpoint the root cause of this issue. Is some DMA state recovery required after the first round of operations? Any suggestions would be highly appreciated.
### Phenomenon
