S3-MSX-PC: Bare-metal MSX2+ emulator with VGA output, USB keyboard & stereo audio on ESP32-S3
Posted: Thu Jun 11, 2026 2:19 pm
Hello ESP32 community!
I'm excited to share a project I've been building for the past several months — a deeply optimized MSX2+ emulator that turns a single ESP32-S3 into a full-fledged 1980s home computer.
WHAT IS IT?
S3-MSX-PC emulates the MSX, MSX2, and MSX2+ computer standards on ESP32-S3, outputting to a real VGA monitor with a USB keyboard and stereo PDM audio. No external video chip. No I2S codec. Just the ESP32-S3, a handful of resistors and capacitors, and your childhood memories.
HARDWARE SETUP (minimalist, no extra ICs)
- ESP32-S3-WROOM-1-N16R8 — main SoC (16 MB Flash, 8 MB PSRAM), $4–12
- Resistors 400Ω 1% (3 pcs) — VGA R-2R ladder high bits
- Resistors 800Ω 1% (3 pcs) — VGA R-2R ladder low bits
- Resistors 330–400Ω (4 pcs) — PDM audio RC filter
- Capacitors 22–40 nF (2 pcs) — PDM audio filter
- Capacitors 47–100 nF (2 pcs) — PDM audio filter
- Capacitors 1–10 µF electrolytic (2 pcs) — DC blocking for audio out
- VGA connector DB15 female — video output
- USB-A connector female — keyboard input
Total BOM cost: under $2 in passives + $4–12 for the ESP32-S3 board.
VIDEO: VGA 640×480@60Hz VIA LCD_CAM + R-2R
Instead of a dedicated video DAC, I use 6 GPIO pins driving a resistor ladder (2 bits per R/G/B channel = 64 colors). The ESP32-S3's LCD_CAM peripheral DMA-blasts pixels directly to the monitor.
Key trick: lcd_byte_order=1 flag gives zero-CPU-cost byte swapping. The palette is pre-shifted during init to map directly to GPIO pin states — no runtime bit manipulation.
GPIO mapping:
- HSync → GPIO 13
- VSync → GPIO 14
- R0/R1 → GPIO 1 / GPIO 2
- G0/G1 → GPIO 4 / GPIO 5
- B0/B1 → GPIO 6 / GPIO 7
AUDIO: STEREO PDM WITH MULTI-STAGE RC FILTER
Two GPIO pins (10 and 11) output high-frequency Pulse-Density Modulated (PDM) bitstreams. A 2nd-order RC low-pass filter smooths the PDM signal into a pulse-width equivalent, which after DC blocking capacitors becomes a line-level signal suitable for headphones or an amplifier.
No I2S codec, no external DAC — just GPIO toggling and passive filtering.
USB HOST: KEYBOARD INPUT
USB-A connector wired to GPIO 19 (D-) and GPIO 20 (D+), with 5V VBUS from the board's own regulator. Plug-and-play USB keyboards, ~2–4 ms input latency (interrupt-driven, software debounce bypassed).
CORE OPTIMIZATIONS FOR ESP32-S3 (XTENSA LX7)
1. Z80 CPU: COMPUTED GOTOS
The standard switch/case opcode dispatcher destroys the Xtensa branch predictor. I replaced it with threaded code (computed gotos), pinning PC and ICount to physical 32-bit registers. This alone gave a massive performance boost.
2. PSRAM LATENCY ELIMINATION
fMSX uses ~400 KB of lookup tables in PSRAM. I replaced them with 1-cycle integer bit-shifts. The core 11 KB tables are locked into DRAM_ATTR to avoid PSRAM stalls entirely.
3. ZERO-HEAP SAVE STATE COMPRESSION
Standard zlib crashes when compressing 4.4 MB machine states. I wrote a custom streaming LZ77 ("Delta-Stride LZ") that understands MSX VRAM geometry (128/256-byte strides), performs vertical rep-match XOR-delta, and streams directly to SD card using exactly 0 bytes of heap RAM.
4. SMART DISK AUTO-SAVE
Disk writes use a dirty-flag system: the 720 KB DSK image lives in PSRAM, all writes happen in RAM, and the SD card is touched only on clean exit/reset. This minimizes SD card wear significantly.
5. Z80 TURBO MODE
Dynamic 2x overclocking (~8.23 MHz equivalent) for computational tasks, while preserving exact hardware timing for I/O ports and VDP polling loops.
SOFTWARE ARCHITECTURE
- Emulation core: fMSX 6.0 (MSX1 / MSX2 / MSX2+)
- Framework: ESP-IDF v5.4.4
- File manager: Wi-Fi AP (retro-go derived) — upload ROMs/DSKs via browser
- Save states: SRAM + instant snapshot with streaming compression
- VGM tracker: PSG, SCC, OPLL multi-channel playback
MEDIA COVERAGE
Featured on CNX-Software:
https://www.cnx-software.com/2026/06/11 ... mizations/
RESOURCES
- GitHub (source, schematic, binaries, technical deep dive):
https://github.com/Svarkovsky/s3-msx-pc
- Demo videos: check the GitHub README — output_.mp4, output2.mp4, output3r.mp4
WHO IS THIS FOR?
- Retro computing enthusiasts who want real VGA + USB keyboard experience
- Embedded developers interested in ESP32-S3 performance tuning
- Makers looking for a minimalist DIY project with no specialized chips
ACKNOWLEDGEMENTS
This project was inspired by retro-go by Alex Duchesne (@ducalex). The Wi-Fi file manager concept and launcher architecture served as invaluable starting points. The rendering pipeline, audio subsystem, and input layer were fundamentally redesigned for the desktop MSX experience.
I'm happy to answer technical questions — especially about LCD_CAM configuration, PSRAM optimization strategies, or the Z80 threaded code implementation.
WHAT IS IT?
GPIO mapping:
- HSync → GPIO 13
- VSync → GPIO 14
5. Z80 TURBO MODE
MEDIA COVERAGE
RESOURCES
WHO IS THIS FOR?
ACKNOWLEDGEMENTS
