Single-pixel vertical lines not rendered correctly with ESP32_Display_Panel RGB framebuffer
Posted: Sat Jul 18, 2026 7:52 pm
Hi all,
Problem: Single-pixel vertical lines not rendered correctly with ESP32_Display_Panel RGB framebuffer
Board: Waveshare ESP32-S3 Touch LCD 4.3" (800×480 RGB, ST7262)
MCU: ESP32-S3
Arduino ESP32 Core: 3.3.5
ESP-IDF: 5.5 (bundled with Arduino core)
Library: ESP32_Display_Panel (current version supplied with Waveshare examples)
Problem
Single-pixel-wide vertical lines written directly into the framebuffer are not displayed correctly.
The problem occurs using the official Waveshare example without any application code.
Reproduction
Starting from the standard Waveshare example (08_DrawColorBar), replace:
lcd->colorBarTest();
with:
auto fb = static_cast<uint16_t *>(lcd->getFrameBufferByIndex(0));
const int W = EXAMPLE_LCD_WIDTH;
const int H = EXAMPLE_LCD_HEIGHT;
// Fill background green
for (int i = 0; i < W * H; i++)
fb = 0x07E0;
// Draw one red vertical line
for (int y = 0; y < H; y++)
fb[y * W + 200] = 0xF800;
Expected result
A green background with a single red vertical line.
Actual result
A green background with a black vertical stripe where the red line should be.
Additional tests
Full-screen fill
fb = 0x07E0;
✔ Works correctly.
Single horizontal line
for (int x = 0; x < W; x++)
fb[200 * W + x] = 0xF800;
✔ Works correctly.
Single vertical line
✘ Displays as a black stripe.
Two adjacent vertical lines
fb[y * W + 201] = 0xF800;
✔ Both lines display correctly.
Five adjacent coloured columns
fb[y * W + 198] = 0xF800;
fb[y * W + 199] = 0xFFE0;
fb[y * W + 200] = 0xFFFF;
fb[y * W + 201] = 0x001F;
fb[y * W + 202] = 0x0000;
✔ All five columns display correctly.
Five isolated single-pixel columns
Columns separated by several pixels:
198 Red
204 Yellow
210 White
216 Blue
222 Black
Results:
Red → black stripe
Yellow → not visible
White → not visible
Blue → black stripe
Black → black stripe
Framebuffer information
Framebuffer pointer obtained using:
Diagnostics:
Framebuffer located in external PSRAM
64-byte aligned
Not DMA capable
RGB driver configured with a bounce buffer (800 × 10 pixels)
Observation
The problem only affects isolated one-pixel-wide vertical features.
Horizontal features render correctly.
Full-screen fills render correctly.
Adjacent vertical pixels render correctly.
The problem is fully reproducible using the vendor example and does not depend on application code.
Question
Is this a known limitation or bug in:
ESP32_Display_Panel
the ESP-IDF RGB panel driver
bounce-buffer handling
PSRAM framebuffer handling
or is an additional synchronization step required after direct framebuffer writes?
Thanks in advance.
MCU: ESP32-S3
Problem
Reproduction
with:
fb = 0x07E0;
Expected result
Actual result
Additional tests
Full-screen fill
fb = 0x07E0;
✔ Works correctly.
✔ Works correctly.
198 Red
204 Yellow
210 White
216 Blue
222 Black
Results:
Red → black stripe
White → not visible
Blue → black stripe
Diagnostics:
64-byte aligned
Not DMA capable
Observation
Question
ESP32_Display_Panel
Thanks in advance.
