Save panic handler output?
Resch2061
Postby Resch2061 » Tue Feb 27, 2018 2:22 pm
Hi all,
Is it possible to somehow save the output of the panic handler? Does it get stored in NVS?
The reason I'm asking is because I'm currently developing something that makes it impossible for me to use make monitor, as the hardware uses the DTR line of the USB. The functionality I'm currently working on will not work when a USB cable is in the device.
kolban
Re: Save panic handler output?
Postby kolban » Tue Feb 27, 2018 3:04 pm
Might the following be of use to you?
http://esp-idf.readthedocs.io/en/latest ... _dump.html
It provides support for crash/dump handling. If a critical error is detected, it will result in a detailed dump being recorded for subsequent examination.
Users browsing this forum: Applebot, PerplexityBot and 4 guests
