Waveshare ESP32‑S3‑Touch‑LCD‑7 — RGB Panel Sync Issue (Stable Fuzz, No Response to Timing Changes)
Posted: Sun Aug 09, 2026 8:33 am
Hi all,
I’m working with the Waveshare ESP32‑S3‑Touch‑LCD‑7 (800×480 RGB panel) using ESP‑IDF v5.2.7.
The ESP32‑S3 is successfully driving HSYNC, VSYNC, DE, and PCLK. The panel responds with an initial aqua flash, then shows stable but incorrect fuzzy output.
Over several weeks I’ve tried:
Verified pinmap against Waveshare demo
Corrected RGB565 bit order (DATA0–DATA15)
Multiple polarity combinations
Multiple pixel clocks (9–21 MHz)
Correct ST7262 timing (1/46/16 and 1/23/7)
Waveshare demo timing (4/8/8)
Verified DE polarity
Verified RGB565 formatting
Verified double‑buffering
Verified that sync signals are stable
Despite this, the image never changes at all, regardless of timing, polarity, or pixel clock.
This strongly suggests the panel is not using ST7262 timing, or is operating in DE‑only mode, or uses a different LCD controller IC (EK79007, EK9716, ST7701, HX8264, etc).
I need the actual timing parameters for the LCD module Waveshare uses in this product:
LCD controller IC model
Pixel clock requirements
HSYNC pulse width / back porch / front porch
VSYNC pulse width / back porch / front porch
Required polarity for HSYNC, VSYNC, DE, PCLK
Whether the panel uses DE‑only mode
Whether 16‑bit or 24‑bit RGB mode is required
If anyone has a working esp_lcd_rgb_panel_config_t for this exact Waveshare board, that would be extremely helpful.
Thanks in advance — any insight appreciated.
Aaron
Newcastle, NSW, Australia
Aaron
