ESP32 Bluetooth Slider LED App
Lelouch
Postby Lelouch » Sun Mar 04, 2018 1:37 am
Hey
I have an app which can read sensor values from the esp32 over BLE and i can also write to the seriell monitor. Now i wanted to make an Slider to controll the brightness of a LED. I found an nice example but it didnt work for me because he uses a arduino101 and has the analogWrite command which dont work on esp. (btw: im using ESP32_BLE_UART example)
if (switchCharacteristic.written()) {
          Serial.println(switchCharacteristic.value());
          int light = map(switchCharacteristic.value(),10,49,0,255);
          analogWrite(lightPin,light);
has some one a idea ? :)
maneco
Re: ESP32 Bluetooth Slider LED App
Postby maneco » Sun Mar 04, 2018 2:33 am
you could use dac output, somthing like:
dacWrite(25,light);
instead of analog write
WiFive
Postby WiFive » Sun Mar 04, 2018 11:06 pm
dacWrite(25,light);
No, because analogwrite in this context is PWM
Lelouch
Postby Lelouch » Sun Mar 04, 2018 11:32 pm
Hey now with this code:
      std::string rxValue = pCharacteristic->getValue();
     if (rxValue.length() > 0) {
         int light = map(rxValue.length(),10,49,0,255);
          Serial.println(rxValue.length());
         dacWrite(LED,light);
i only get 4 4 4 .... what do i have to write instead of length ?
btw: I think I recieve strings .. so will this work ?.. sry im pretty noob in programming
Users browsing this forum: Bytespider, Qwantbot and 1 guest
