RMT - simplest receive example working, but idle_threshold problem
Thildemar
Re: RMT - simplest receive example working, but idle_threshold problem
Postby Thildemar » Wed Oct 09, 2019 1:29 pm
Thanks, I'll see if this works for my project. Cheers!
jw--rt
Postby jw--rt » Wed Nov 13, 2019 7:27 pm
Hello everyone,
That last solution works like a charm for me! It's a bit hacky, but whatever!
What I changed is: I just readout the first value in memory and immediately after that use:
rmt_item32_t* item = nullptr; // NULL
rmt_rx_start(RMT_CHANNEL_N, true);
for(;;)
    item = (rmt_item32_t*) (RMT_CHANNEL_MEM(RMT_CHANNEL_N));
    // Do math with item->duration0 and item->duration1
    rmt_memory_rw_rst(RMT_CHANNEL_N);
    vTaskDelay(DELAY_TIME_MS/portTICK_PERIOD_MS);
Thank you @jcsbanks for putting your time into investigating that!
Additionally, it solves my problem in my post viewtopic.php?t=12873.
I just haven't thought about using the RMT module.
Best regard,
jw--rt
jcsbanks
Postby jcsbanks » Wed Nov 13, 2019 9:12 pm
Is that loop ever going to be blocked/yield or just burn up CPU cycles?
jw--rt
Postby jw--rt » Wed Nov 13, 2019 9:50 pm
good point. For completeness, I edited my answer.
Best regards,
jw--rt
Users browsing this forum: No registered users and 25 guests
