UART Send Raw Bytes
UART Send Raw Bytes
The SDK UART API seems to send character only. How do I send a RAW byte? For example, I want to send data 0xAA.
Re: UART Send Raw Bytes
Might the uart_write_bytes API do the trick?
I have the following code:
int sendData(const char* logName, const char* data)
const int len = strlen(data);
const int txBytes = uart_write_bytes(UART_NUM_2, data, len);
ESP_LOGI(logName, "Wrote %d bytes", txBytes);
return txBytes;
static void tx_task()
static const char *TX_TASK_TAG = "TX_TASK";
while (1) {
sendData(TX_TASK_TAG, 0xAA);
vTaskDelay(2000 / portTICK_PERIOD_MS);
How do I declare the 0xAA as a byte? Currently the code expecting a string.
return txBytes;
while (1) {
Howdy my friend
how about
In this case, pass the size of your data buffer in as a parameter.
how about
char data[] = { 0xAA };
sendData(data, sizeof(data));
Users browsing this forum: Baidu [Spider], Bytespider, ChatGPT-User, Google [Bot], PetalBot, Semrush [Bot] and 10 guests
