ESP32 Bluetooth SPP with bidirectional communication (send and receive)
newsettler_AI
Postby newsettler_AI » Fri Apr 06, 2018 10:40 am
I need that ESP can send and receive data over SPP while connected to Android smartphone (let say, using any spp terminal I need to receive and send commands).
In IDF examples there are 2 examples for acceptor and initiator. I have checked acceptor and it works fine. Only one thing - it working only in one directional Android -> ESP.
Is it possible to make comunication bidirectional?
I'm looking over code in both acceptor and initiator and I'm not sure is it even possible, as I see at one example ESP is slave and in another master.
There are essential difference in callbacks for processing SPP events:
acceptor:
static const esp_spp_role_t role_slave = ESP_SPP_ROLE_SLAVE;
    case ESP_SPP_INIT_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_INIT_EVT");
        esp_bt_dev_set_device_name(EXCAMPLE_DEVICE_NAME);
        esp_bt_gap_set_scan_mode(ESP_BT_SCAN_MODE_CONNECTABLE_DISCOVERABLE);
        esp_spp_start_srv(sec_mask,role_slave, 0, SPP_SERVER_NAME);
    case ESP_SPP_DISCOVERY_COMP_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_DISCOVERY_COMP_EVT");
       // do nothing!!!
    case ESP_SPP_OPEN_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_OPEN_EVT");
       // do nothing!!!
initiator
static const esp_spp_role_t role_master = ESP_SPP_ROLE_MASTER;
        esp_bt_gap_start_discovery(inq_mode, inq_len, inq_num_rsps);
        ESP_LOGI(SPP_TAG, "ESP_SPP_DISCOVERY_COMP_EVT status=%d scn_num=%d",param->disc_comp.status, param->disc_comp.scn_num);
        if (param->disc_comp.status == ESP_SPP_SUCCESS) {
            esp_spp_connect(sec_mask, role_master, param->disc_comp.scn[0], peer_bd_addr);
        esp_spp_write(param->srv_open.handle, SPP_DATA_LEN, spp_data);
        gettimeofday(&time_old, NULL);
And which role should be Android smartphone in case bidirectional communication with ESP?
Please advice, maybe there are some ready robust solutions for bidirectional communication over SPP?
loboris
Re: ESP32 Bluetooth SPP with bidirectional communication (send and receive)
Postby loboris » Fri Apr 06, 2018 1:11 pm
You just have to combine receiving and sending, like in this simple example based on example_spp_acceptor_demo.c
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <stdio.h>
#include "nvs.h"
#include "nvs_flash.h"
#include "freertos/task.h"
#include "esp_log.h"
#include "esp_bt.h"
#include "esp_bt_main.h"
#include "esp_gap_bt_api.h"
#include "esp_bt_device.h"
#include "esp_spp_api.h"
#include "time.h"
#include "sys/time.h"
#define SPP_TAG "SPP_ACCEPTOR_DEMO"
#define SPP_SERVER_NAME "SPP_SERVER"
#define EXCAMPLE_DEVICE_NAME "ESP_SPP_ACCEPTOR"
#define SPP_SHOW_DATA 0
#define SPP_SHOW_SPEED 1
#define SPP_SHOW_MODE SPP_SHOW_DATA    /*Choose show mode: show data or speed*/
static const esp_spp_mode_t esp_spp_mode = ESP_SPP_MODE_CB;
static struct timeval time_new, time_old;
static long data_num = 0;
static const esp_spp_sec_t sec_mask = ESP_SPP_SEC_NONE;
static void print_speed(void)
    float time_old_s = time_old.tv_sec + time_old.tv_usec / 1000000.0;
    float time_new_s = time_new.tv_sec + time_new.tv_usec / 1000000.0;
    float time_interval = time_new_s - time_old_s;
    float speed = data_num * 8 / time_interval / 1000.0;
    ESP_LOGI(SPP_TAG, "speed(%fs ~ %fs): %f kbit/s" , time_old_s, time_new_s, speed);
    data_num = 0;
    time_old.tv_sec = time_new.tv_sec;
    time_old.tv_usec = time_new.tv_usec;
static void esp_spp_cb(esp_spp_cb_event_t event, esp_spp_cb_param_t *param)
    char buf[1024];
    char spp_data[256];
    switch (event) {
    case ESP_SPP_CLOSE_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CLOSE_EVT");
    case ESP_SPP_START_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_START_EVT");
    case ESP_SPP_CL_INIT_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CL_INIT_EVT");
    case ESP_SPP_DATA_IND_EVT:
#if (SPP_SHOW_MODE == SPP_SHOW_DATA)
        ESP_LOGI(SPP_TAG, "ESP_SPP_DATA_IND_EVT len=%d handle=%d",
                 param->data_ind.len, param->data_ind.handle);
        if (param->data_ind.len < 1023) {
            snprintf(buf, (size_t)param->data_ind.len, (char *)param->data_ind.data);
            printf("%s\n", buf);
            sprintf(spp_data, "Receined characters: %d\n", param->data_ind.len);
            esp_spp_write(param->write.handle, strlen(spp_data), (uint8_t *)spp_data);
        else {
            esp_log_buffer_hex("",param->data_ind.data,param->data_ind.len);
#else
        gettimeofday(&time_new, NULL);
        data_num += param->data_ind.len;
        if (time_new.tv_sec - time_old.tv_sec >= 3) {
            print_speed();
#endif
    case ESP_SPP_CONG_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CONG_EVT");
    case ESP_SPP_WRITE_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_WRITE_EVT");
    case ESP_SPP_SRV_OPEN_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_SRV_OPEN_EVT");
    default:
void app_main()
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
    ESP_ERROR_CHECK( ret );
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    if (esp_bt_controller_init(&bt_cfg) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s initialize controller failed\n", __func__);
        return;
    if (esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s enable controller failed\n", __func__);
        return;
    if (esp_bluedroid_init() != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s initialize bluedroid failed\n", __func__);
        return;
    if (esp_bluedroid_enable() != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s enable bluedroid failed\n", __func__);
        return;
    if (esp_spp_register_callback(esp_spp_cb) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s spp register failed\n", __func__);
        return;
    if (esp_spp_init(esp_spp_mode) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s spp init failed\n", __func__);
        return;
Tested with Bluetooth terminal Android application.
oclyke
Postby oclyke » Wed Oct 10, 2018 3:52 am
Thanks loboris, worked great.
PawelJalocha
Postby PawelJalocha » Sat Oct 27, 2018 10:18 pm
Hello, I need the SPP mode too and actually I am not able to make it to work at all.
With some older ESP-IDF I was able to get to a point where the BT was reported as audio device thus could not connect it as serial port
with the newer ESP-IDF it is still reported as audio but is mostly dead thus no callbacks, etc.
Would appreciate help to make it work.
Pawel.
tommeyers
Postby tommeyers » Sun Oct 28, 2018 2:19 pm
This worked for me:
#include "BluetoothSerial.h"
//===== Preferences Manager:  (hack so that I can return a preference data type)
//                            see: https://playground.arduino.cc/Code/Struct#Creation
#include "name.h"
BluetoothSerial SerialBT;
  //add:     PreferenceAdd(preferenceName,preferenceLabel,defaultValue,regexValidation (javascript regex),description);
  preferenceAdd("wifiname",      "WiFi SSID",     "Wireless-N",         "^[A-Z|a-z|-]{5}$",                              "WiFi SSID");
  preferenceAdd("wifipwd",       "WiFi Password", "xyzzy3585",          "^[A-Z|a-z|0-9]{10}$",                           "WiFi Password");
  preferenceAdd("mqttip",        "MQTT IP",       "192.168.1.250",      "^[0-9|.{15}$",                                  "MQTT Broker IP");
  preferenceAdd("nodename",      "MQTT Node",     "Node01",             "^[A-Z|a-z|0-9]{5}$",                            "Node name for MQTT");
  setupBT();
String receivedSerialString   = "";
  processBT();
//==  BT interface for preferences/nvs ======================================================
String receivedSerialBTString = "";
void setupBT() {
  SerialBT.begin("ESP32test"); //Bluetooth device name
  SerialBT.flush();
  Serial.println("The device started, now you can pair it and connect from another bluetooth");
void processBT() {
  char receivedBTChar;
  while (SerialBT.available()) {
    receivedBTChar = SerialBT.read();
    receivedSerialBTString = receivedSerialBTString + receivedBTChar;
    if (receivedBTChar == '\n') {
      // ===== hello
      if (receivedSerialBTString.startsWith("hello")) {
          SerialBT.print("hello\n");
          continue;
      // ===== reboot
      if (receivedSerialBTString.startsWith("reboot")) {
          SerialBT.print("rebooting      - reconnect\n");
          //SerialBT.flush();
          //delay(1000);
          esp_restart();
      // ===== preferences get and update
      if (receivedSerialBTString.startsWith("preferences")) {
          if(receivedSerialBTString.substring(12).startsWith("get") ) {
            Serial.print("preferences/get");Serial.print(" senting: "); Serial.println(preferenceGetCount());
                            //        1         1         1         1
                            //0         1         2         3         4         5         6         7         8         9         0         1         2         1
                            //01234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
                            //                   name           label         value              regex                                     description
                            //preferences gotten wifiname       WiFi SSID     Wireless-N         /.*/                                      WiFi SSID\n");
            for (int i = 0; i < preferenceGetCount(); i++) {
              SerialBT.print("preferences gotten "
                             + (preferenceGetInfo(i).preferenceName   + "                                             ").substring(0,15)
                             + (preferenceGetInfo(i).preferenceLabel  + "                                             ").substring(0,14)
                             + (preferenceGetInfo(i).actualValue      + "                                             ").substring(0,19)
                             + (preferenceGetInfo(i).regexValidation  + "                                             ").substring(0,41)
                             + (preferenceGetInfo(i).description      + "                                             ").substring(0,23)
                             + "\n");
            continue;
          // ===== preferences update
          if(receivedSerialBTString.substring(12).startsWith("update") ) {
              //        1         1         1         1
              //                   name           value
              //preferences update wifiname       Wireless-N
              receivedSerialBTString = receivedSerialBTString + "                    ";  // trailing spaces so substring(19,33) is in range
              String nameString = receivedSerialBTString.substring(19,33);
              String valueString = receivedSerialBTString.substring(34);
              nameString.trim();  //because trim() modifies in-place see: https://www.arduino.cc/reference/en/language/variables/data-types/string/functions/trim/
              valueString.trim(); //because trim() modifies in-place see: https://www.arduino.cc/reference/en/language/variables/data-types/string/functions/trim/
              preferenceUpdate(nameString, valueString);
              continue;
          // ===== defaults
          if(receivedSerialBTString.substring(15).startsWith("defaults") ) {
            preferenceReset();
            continue;
      Serial.println("Unknown: " + receivedSerialBTString);
      continue;
// ===== Preferences Manager" Access to preference Name/Values in NVS
//       implements: Add (to list and NVS); Reset: (all values in list are set to defaults and NVS too); update: (change list value and NVS value)
//                   getCount and getPreference
#include <FS.h>
#include <Preferences.h>
Preferences preferences;
preferenceInfo preferenceList[20];
int preferenceCount = 0;
//===== Preferences Manager:  return one of the array
preferenceInfo preferenceGetInfo(int index) {
  return preferenceList[index];
//===== Preferences Manager:  return the count of preferences in the array
int preferenceGetCount() {
  return preferenceCount;
//===== Preferences Manager:  Adds a preference to the list and to the NVS "preferences"
void preferenceAdd(String preferenceName,String preferenceLabel,String defaultValue,String regexValidation,String description) { // Add an item and put its value (or default) in table
           // Serial.print(preferenceGetInfo[0].description);
            preferenceList[preferenceCount].preferenceName  = preferenceName;
            preferenceList[preferenceCount].preferenceLabel  = preferenceLabel;
            preferenceList[preferenceCount].defaultValue    = defaultValue;
            preferenceList[preferenceCount].regexValidation = regexValidation;
            preferenceList[preferenceCount].description     = description;
            preferences.begin("preferences",false);
            preferenceList[preferenceCount].actualValue = preferences.getString(preferenceName.c_str(), defaultValue.c_str());
            preferences.end();
            preferenceCount++;
//===== Preference Manager: Sets all preferences in the list to their default (does not clear/change others in NVS but not in list)
void preferenceReset() {                                               //clear all and set the list of values to their default
              for (int i = 0; i < preferenceCount; i++) {
                preferences.putString(preferenceList[i].preferenceName.c_str(), preferenceList[i].defaultValue.c_str());
                preferenceList[i].actualValue = preferences.getString(preferenceList[i].preferenceName.c_str(), preferenceList[i].defaultValue.c_str());
              preferences.end();
              return;
//===== Preference Manager: Changes the preference value in NVS and sets the actualValue in the list
void preferenceUpdate(String preferenceName,String preferenceValue) {  // Change an items value and update the table
              //Serial.println("compare:" + preferenceList[i].preferenceName + "/" + preferenceName + "/" +  preferenceValue);
              if (preferenceList[i].preferenceName == preferenceName) {
                //Serial.print("Changed:  "); Serial.print(preferenceName.c_str()); Serial.print("/"); Serial.println(preferenceValue.c_str());
                preferenceList[i].actualValue = preferenceValue;
                preferences.putString(preferenceName.c_str(),preferenceValue.c_str());
                //Serial.println("Verify:" +  preferences.getString(preferenceList[i].preferenceName.c_str(), "999"));
          preferences.end();
          return;
I access it with a my chrome add-in.
IT Professional, Maker
Santiago, Dominican Republic
PawelJalocha
Postby PawelJalocha » Sun Oct 28, 2018 3:32 pm
OK, I am working with ESP-IDF and I actually got to the stage where I can see and pair the BT of my ESP32 in classic BT mode.
But, it refuses to connect, which I suspect is because the ESP32 is seen as audio-card and not a serial port.
Is there a way to resolve this situation ?
Are there any parameters on the ESP32 which affect the way external devices like laptops or tablets see the BT object ?
Pawel.
tommeyers
Postby tommeyers » Sun Oct 28, 2018 4:48 pm
You might try a BT sniffer to get more info.
I used BT Serial library and my esp32 presented SPP.
I also used a BT Sniffer in the process.
PawelJalocha
Postby PawelJalocha » Sun Oct 28, 2018 5:06 pm
Here is what I see with the Linux bluetoothctl:
Class: 0x2c0414
Icon: audio-card
Paired: yes
Trusted: no
Blocked: no
Connected: no
LegacyPairing: no
UUID: Serial Port (00001101-0000-1000-8000-00805f9b34fb)
RSSI: -54
the problem is the "audio-card" - this way laptops and tablets see this BT device.
Connection attempts fail with the message:
Failed to connect: org.bluez.Error.NotAvailable
georgecarlo
Postby georgecarlo » Fri Feb 01, 2019 10:15 am
#include <stdint.h>
#include <string.h>
#include <stdio.h>
#include "nvs.h"
#include "esp_bt.h"
#include "time.h"
    data_num = 0;
    char buf[1024];
    char spp_data[256];
    switch (event) {
        else {
#else
            print_speed();
#endif
    default:
void app_main()
        return;
        return;
        return;
        return;
        return;
        return;
sorry for the bump, but i need some clarification. thanks loboris, this code works, but this comes under data_ind event. i just want to perform a loop function(i have one) when bt connects so that the code prints with esp_spp_write until loop ends, where do i need to place the code in the event??
gunar.kroeger
Postby gunar.kroeger » Fri Feb 01, 2019 11:11 am
I find that the best way is to put your loop with esp_spp_write on a separate task.
To receive replies, make a queue and use the event only to put received messages into the queue, and process the message from the queue on the task also.
But I suggest using a strict request-reply protocol, because if you try to send messages in bulk you will end up getting congestion events and losing data. Until this day we haven't got a solution to this (https://www.esp32.com/viewtopic.php?f=1 ... 3&start=10) and will have to deal with low throughput
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
Users browsing this forum: ChatGPT-User, PetalBot, Qwantbot and 10 guests
