ESP32 Bluetooth SPP with bidirectional communication (send and receive)
suriyaelango
Re: ESP32 Bluetooth SPP with bidirectional communication (send and receive)
Postby suriyaelango » Mon Mar 11, 2019 2:12 pm
Can someone please tell me if Bluetooth SPP supports multiple clients in case of bi-directional communication? If yes, implementation code, please.
gunar.kroeger
Postby gunar.kroeger » Tue Mar 12, 2019 4:20 pm
suriyaelango wrote: Hi,
It does. You will have to save the connection handle from incoming clients and direct the messages with esp_spp_write to the correct handle
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
suriyaelango
Postby suriyaelango » Mon Mar 18, 2019 7:57 am
The esp_spp_write function is an IDF function. Any chance it works with the Arduino framework for ESP32?
ESP_Me-no-dev
Postby ESP_Me-no-dev » Tue Mar 19, 2019 4:01 pm
We already have a library and example in Arduino for SPP use: https://github.com/espressif/arduino-es ... rialBT.ino
SpartaYigit
Postby SpartaYigit » Wed Mar 20, 2019 7:29 pm
The BluetoothSerial library does not allow to connect directly to other devices (when a UUID is given) using SPP. Is this correct? If not, is there an example to do this in Arduino?
(I want to connect the ESP32 to the Neurosky Mindwave Mobile which uses Serial Port Profile (classic bluetooth). I have looked into the SPP_initiator example and it allows me to connect to the device but couldn't receive any data from it.)
JWardell
Postby JWardell » Wed Apr 24, 2019 3:33 am
I'm trying to do the same thing, to connect to an existing bluetooth serial device. Have you figured out a way to do with with Arduino?
Thanks.
SpartaYigit
Postby SpartaYigit » Wed Apr 24, 2019 12:37 pm
Thanks.
Yeah, currently it is working with arduino. I have changed the bluetooth serial library to allow connecting to the Mindwave headset. The only problem left is the data that i am receiving. I can only see the raw data that the headset sends over (every 2 ms). I cannot seem to get the eSense values out of it which is sent every 1 second. Maybe we can help eachother out.
JWardell
Postby JWardell » Thu Apr 25, 2019 2:39 am
So you had to modify the bluetooth serial library to allow pairing etc, or did you change to a different library? How difficult is it? Is there a way to get a list of discoverable devices?
Trying to find what you are trying to interface with, some kind of EEG?
SpartaYigit
Postby SpartaYigit » Sun Apr 28, 2019 8:24 am
Correct, I was trying to get the brainwave values from a Neurosky MindWave headset through the bluetooth conection.
I modified the Bluetooth Serial library with the SPP_initiator example from ESP32-IDF to have the buffer functionality of the library when data is being received. It was a lot of work in the beginning to understand the code but now it finally works. There is code available on Qita https://qiita.com/ajtajta_j/items/297c6191635b47c945cb from which i started to directly connect to a device when the UUID is known (but has no buffer). There is a bt_discovery example on GitHub to see a list of discoverable devices.
Feel free to ask if something is not clear.
kluverp
Postby kluverp » Mon Nov 18, 2019 10:00 am
loboris wrote:
Fri Apr 06, 2018 1:11 pm
You just have to combine receiving and sending, like in this simple example based on example_spp_acceptor_demo.c
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <stdio.h>
#include "nvs.h"
#include "nvs_flash.h"
#include "freertos/task.h"
#include "esp_log.h"
#include "esp_bt.h"
#include "esp_bt_main.h"
#include "esp_gap_bt_api.h"
#include "esp_bt_device.h"
#include "esp_spp_api.h"
#include "time.h"
#include "sys/time.h"
#define SPP_TAG "SPP_ACCEPTOR_DEMO"
#define SPP_SERVER_NAME "SPP_SERVER"
#define EXCAMPLE_DEVICE_NAME "ESP_SPP_ACCEPTOR"
#define SPP_SHOW_DATA 0
#define SPP_SHOW_SPEED 1
#define SPP_SHOW_MODE SPP_SHOW_DATA    /*Choose show mode: show data or speed*/
static const esp_spp_mode_t esp_spp_mode = ESP_SPP_MODE_CB;
static struct timeval time_new, time_old;
static long data_num = 0;
static const esp_spp_sec_t sec_mask = ESP_SPP_SEC_NONE;
static const esp_spp_role_t role_slave = ESP_SPP_ROLE_SLAVE;
static void print_speed(void)
    float time_old_s = time_old.tv_sec + time_old.tv_usec / 1000000.0;
    float time_new_s = time_new.tv_sec + time_new.tv_usec / 1000000.0;
    float time_interval = time_new_s - time_old_s;
    float speed = data_num * 8 / time_interval / 1000.0;
    ESP_LOGI(SPP_TAG, "speed(%fs ~ %fs): %f kbit/s" , time_old_s, time_new_s, speed);
    data_num = 0;
    time_old.tv_sec = time_new.tv_sec;
    time_old.tv_usec = time_new.tv_usec;
static void esp_spp_cb(esp_spp_cb_event_t event, esp_spp_cb_param_t *param)
    char buf[1024];
    char spp_data[256];
    switch (event) {
    case ESP_SPP_INIT_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_INIT_EVT");
        esp_bt_dev_set_device_name(EXCAMPLE_DEVICE_NAME);
        esp_bt_gap_set_scan_mode(ESP_BT_SCAN_MODE_CONNECTABLE_DISCOVERABLE);
        esp_spp_start_srv(sec_mask,role_slave, 0, SPP_SERVER_NAME);
    case ESP_SPP_DISCOVERY_COMP_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_DISCOVERY_COMP_EVT");
    case ESP_SPP_OPEN_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_OPEN_EVT");
    case ESP_SPP_CLOSE_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CLOSE_EVT");
    case ESP_SPP_START_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_START_EVT");
    case ESP_SPP_CL_INIT_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CL_INIT_EVT");
    case ESP_SPP_DATA_IND_EVT:
#if (SPP_SHOW_MODE == SPP_SHOW_DATA)
        ESP_LOGI(SPP_TAG, "ESP_SPP_DATA_IND_EVT len=%d handle=%d",
                 param->data_ind.len, param->data_ind.handle);
        if (param->data_ind.len < 1023) {
            snprintf(buf, (size_t)param->data_ind.len, (char *)param->data_ind.data);
            printf("%s\n", buf);
            sprintf(spp_data, "Receined characters: %d\n", param->data_ind.len);
            esp_spp_write(param->write.handle, strlen(spp_data), (uint8_t *)spp_data);
        else {
            esp_log_buffer_hex("",param->data_ind.data,param->data_ind.len);
#else
        gettimeofday(&time_new, NULL);
        data_num += param->data_ind.len;
        if (time_new.tv_sec - time_old.tv_sec >= 3) {
            print_speed();
#endif
    case ESP_SPP_CONG_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CONG_EVT");
    case ESP_SPP_WRITE_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_WRITE_EVT");
    case ESP_SPP_SRV_OPEN_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_SRV_OPEN_EVT");
        gettimeofday(&time_old, NULL);
    default:
void app_main()
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
    ESP_ERROR_CHECK( ret );
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    if (esp_bt_controller_init(&bt_cfg) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s initialize controller failed\n", __func__);
        return;
    if (esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s enable controller failed\n", __func__);
        return;
    if (esp_bluedroid_init() != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s initialize bluedroid failed\n", __func__);
        return;
    if (esp_bluedroid_enable() != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s enable bluedroid failed\n", __func__);
        return;
    if (esp_spp_register_callback(esp_spp_cb) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s spp register failed\n", __func__);
        return;
    if (esp_spp_init(esp_spp_mode) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s spp init failed\n", __func__);
        return;
Tested with Bluetooth terminal Android application.
I have this working, but what I wonder is, why does sending data with "esp_epp_write()" causing to receive the same data on the client as well? Only on a per-char basis like so when sending the string "Hello!":
I (230963) SPP_ACCEPTOR_DEMO: ESP_SPP_DATA_IND_EVT len=1 handle=129
H
I (230973) SPP_ACCEPTOR_DEMO: ESP_SPP_DATA_IND_EVT len=1 handle=129
e
l
I (230983) SPP_ACCEPTOR_DEMO: ESP_SPP_DATA_IND_EVT len=1 handle=129
l
I (230993) SPP_ACCEPTOR_DEMO: ESP_SPP_DATA_IND_EVT len=1 handle=129
o
Users browsing this forum: No registered users and 20 guests
