hw fifo overflow max set / reset
Postby rudi ;-) » Sun Nov 20, 2016 11:38 pm
hi guys
#define UART_FIFO_LEN           (128)        /*!< Length of the hardware FIFO buffers */
how much we can set fifo for uart in extrem example and how much you suggest for max?
can we read, reset overflow bit by user?
reset Fifo after read by user ?
uart_reg->int_clr.txfifo_empty = 1;
uart_reg->int_ena.txfifo_empty = 1;
//Event of HW FIFO overflow detected
                  case UART_FIFO_OVF:
                      ESP_LOGI(TAG, "hw fifo overflow\n");
btw, we have rxfifo and txfifo,
hw fifo respekt UART_FIFO_OVF means allways rxfifo ?
btw: CAN Register works just in time pefekt ( 1000 msg )
only uart hw fifo ovf - have not insert fifo reset after INTR.
hw fifo overflow.png (10.46 KiB) Viewed 17479 times
WiFive
Re: hw fifo overflow max set / reset
Postby WiFive » Mon Nov 21, 2016 4:04 am
Max is 128. The idea is to set threshold on number of bytes before the interrupt is triggered.
Postby rudi ;-) » Wed Nov 23, 2016 10:06 am
txs, WiFive,
do you or folks know from head how can hw Fifo check fast and clear the bit?
( src ? / info ? )
( i search just in time this and for controll the ring buffer )
i play with this
and see not the clear doing for hw Fifo. perhabs to much fog for my 8-) :mrgreen:
the event "hw Fifo" can be processed - how/where i can find this info ?
} else if(uart_intr_status & UART_RXFIFO_OVF_INT_ST_M) {
            UART_ENTER_CRITICAL_ISR(&uart_spinlock[uart_num]);
            uart_reg->conf0.rxfifo_rst = 1;
            uart_reg->conf0.rxfifo_rst = 0;
            uart_reg->int_clr.rxfifo_ovf = 1;
            UART_EXIT_CRITICAL_ISR(&uart_spinlock[uart_num]);
            uart_event.type = UART_FIFO_OVF;
clear..all other..
else {
            uart_reg->int_clr.val = uart_intr_status; /*simply clear all other intr status*/
            uart_event.type = UART_EVENT_MAX;
uart_reg->int_clr.val = UART_RXFIFO_FULL_INT_CLR_M | UART_RXFIFO_TOUT_INT_CLR_M;
Postby rudi ;-) » Wed Nov 23, 2016 11:34 am
hi
where is UART defined?
uart_dev_t* uart_reg = UART[uart_num];
txs
Postby rudi ;-) » Wed Nov 23, 2016 11:45 am
hi
txs
// static const char* UART_TAG = "UART";
static uart_dev_t* UART[UART_NUM_MAX] = {&UART0, &UART1, &UART2};
int ValReg = 0;
      int uart_num = (int)pvParameters;
      uart_event_t event;
	  uart_dev_t* uart_reg = UART[uart_num];  // yeap..
Postby rudi ;-) » Wed Nov 23, 2016 2:15 pm
hi,
when/where we must do this?
in the ISR after clear the bits?
uart_flush(uart_num);
esp_err_t uart_flush(uart_port_t uart_num)
    UART_CHECK((uart_num < UART_NUM_MAX), "uart_num error", ESP_FAIL);
    UART_CHECK((p_uart_obj[uart_num]), "uart driver error", ESP_FAIL);
    uart_obj_t* p_uart = p_uart_obj[uart_num];
    uint8_t* data;
    size_t size;
    //rx sem protect the ring buffer read related functions
    xSemaphoreTake(p_uart->rx_mux, (portTickType)portMAX_DELAY);
    ESP_INTR_DISABLE(p_uart->intr_num);
    while(true) {
        if(p_uart->rx_head_ptr) {
            vRingbufferReturnItem(p_uart->rx_ring_buf, p_uart->rx_head_ptr);
            p_uart->rx_ptr = NULL;
            p_uart->rx_cur_remain = 0;
            p_uart->rx_head_ptr = NULL;
        data = (uint8_t*) xRingbufferReceive(p_uart->rx_ring_buf, &size, (portTickType) 0);
        if(data == NULL) {
        vRingbufferReturnItem(p_uart->rx_ring_buf, data);
    ESP_INTR_ENABLE(p_uart->intr_num);
    xSemaphoreGive(p_uart->rx_mux);
    if(p_uart->tx_buf_size > 0) {
        xSemaphoreTake(p_uart->tx_mux, (portTickType)portMAX_DELAY);
        UART_ENTER_CRITICAL(&uart_spinlock[uart_num]);
        UART[uart_num]->int_ena.txfifo_empty = 0;
        UART[uart_num]->int_clr.txfifo_empty = 1;
        UART_EXIT_CRITICAL(&uart_spinlock[uart_num]);
        do {
            data = (uint8_t*) xRingbufferReceive(p_uart->tx_ring_buf, &size, (portTickType) 0);
            if(data == NULL) {
        } while(1);
        p_uart->tx_brk_flg = 0;
        p_uart->tx_brk_len = 0;
        p_uart->tx_head = NULL;
        p_uart->tx_len_cur = 0;
        p_uart->tx_len_tot = 0;
        p_uart->tx_ptr = NULL;
        p_uart->tx_waiting_brk = 0;
        p_uart->tx_waiting_fifo = false;
        xSemaphoreGive(p_uart->tx_mux);
    uart_reset_fifo(uart_num);
    return ESP_OK;
Postby rudi ;-) » Wed Nov 23, 2016 8:24 pm
static esp_err_t uart_reset_fifo(uart_port_t uart_num);
                  case UART_FIFO_OVF:
					  // uart_reg->int_clr.val = UART_RXFIFO_FULL_INT_CLR_M | UART_RXFIFO_TOUT_INT_CLR_M;
					  // UART_RXFIFO_OVF_INT_ST_M
					  uart_reg->int_clr.val = UART_RXFIFO_OVF_INT_ST_M;
					  reg_delay();
					  ESP_LOGI(TAG, "cleared..\n");
					   ESP_LOGI(TAG, "uart_flush cleared..\n");
					  // reset
					   ESP_LOGI(TAG, "fifo reset\r\n");
                  //Event of UART ring buffer full
                  case UART_BUFFER_FULL:
                      ESP_LOGI(TAG, "ring buffer full\n");
					  reg_delay();
					  ESP_LOGI(TAG, "ringbuffer int cleared..\n");
..../build/main\libmain.a(uart_main.o):(.literal.uart_task+0x64): undefined reference to `uart_reset_fifo'
WiFive
Postby WiFive » Wed Nov 23, 2016 9:00 pm
It is not exported in UART.h
But really you are supposed to design UART code to avoid overflow for expected data stream. You may need to interrupt more frequently to empty the fifo into the ring buffer or make a bigger ring buffer or use hw/sw flow control or wait for DMA support.
Postby rudi ;-) » Thu Nov 24, 2016 1:13 am
thank you WiFive,
i do now a delay between the send data - and for first - it works - the fifo ovf do not fire now
but the (ring) buffer i think is too small, there are missings thing ( last picture )
i have test the example uart code with task.
now i try to build/design the UART code to avoid overflow for expected data stream, also the ring buffer.
i saw the UHCI (=uart dma )in the 1.0 plan - this would be a goal for this too :P
i will try to handle the things now ( ring buffer, fifo ) - must deeper read .
the good things are, that the register write/clear now ok without mistake.
i do this after each write/clear and it helps:
void reg_delay (void) {
	__asm__ __volatile__("nop;nop;nop;nop;nop;nop;nop;nop;");
Users browsing this forum: Applebot, Semrush [Bot] and 2 guests
