Wake up device from deep-sleep on interrupt
kishan patel
Postby kishan patel » Sat Apr 14, 2018 7:00 am
How can i wake-up the module from the deep_sleep mode,if external interrupt occur?.
Thanks in advance,
Regards,
Kishan Patel.
kishan patel
Re: Wake up device from deep-sleep on interrupt
Postby kishan patel » Mon Apr 16, 2018 7:17 am
Thanks,
Finally,i have used as below,and its working fine.I have doubt about it,can i use number of interrupts on EXT0/EXT1.
I want to say that if i use 2 pins on ext0,only one pin is working.So,i have to use 2 different interrupts(EXT0 & EXT1) as below:
ESP_ERROR_CHECK(rtc_gpio_init(GPIO_NUM_2));
ESP_ERROR_CHECK(gpio_pullup_dis(GPIO_NUM_2));
ESP_ERROR_CHECK(gpio_pulldown_en(GPIO_NUM_2));
ESP_ERROR_CHECK(esp_deep_sleep_enable_ext0_wakeup(GPIO_NUM_2, 1));
ESP_ERROR_CHECK(rtc_gpio_init(GPIO_NUM_15));
ESP_ERROR_CHECK(esp_deep_sleep_enable_ext1_wakeup(BIT(GPIO_NUM_15), ESP_EXT1_WAKEUP_ANY_HIGH));
Regards,
Kishan Patel.
Users browsing this forum: Bing [Bot], meta-externalagent, PerplexityBot, YisouSpider and 2 guests
