Crash on boot (even with BareMinimum code)
Posted: Thu Apr 19, 2018 11:10 am
My code project was working fine but when I came back to it at a later date (without changing anything) it no longer booted.
The serial console shows that its crashing on startup with this error:
This references NVS which I am using in my project (but haven't touched recently). Next, I tried to load the blink example to the chip. That gave this similar error:
Where the backtrace is different (Exception decoder has (seemingly) completely different results too). My first guess was the NVS data could be corrupted but I am not sure how I could prove or fix this, especially seeing as I can't just upload code to clear it.
I am using the ESP-WROOM-32.
Any help or tips would be appreciated!
assertion "entry < ENTRY_COUNT" failed: file "/Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/nvs_flash/src/nvs_page.hpp", line 188, function: uint32_t nvs::Page::getEntryAddress(size_t) const
abort() was called at PC 0x400d1c7b on core 0
Backtrace: 0x400876e0:0x3ffc6500 0x400878bb:0x3ffc6520 0x400d1c7b:0x3ffc6540 0x400d464b:0x3ffc6570 0x400d4c2f:0x3ffc6590 0x400d5885:0x3ffc65e0 0x400d3f16:0x3ffc6640 0x400d3b8a:0x3ffc6690 0x400d3c23:0x3ffc66b0 0x400d3c6e:0x3ffc66d0 0x400e3ba4:0x3ffc66f0 0x400e3b53:0x3ffc6710 0x400d2806:0x3ffc6740Code: Select all
abort() was called at PC 0x400d128f on core 0
Backtrace: 0x40087234:0x3ffc6350 0x4008740f:0x3ffc6370 0x400d128f:0x3ffc6390 0x400e3d5b:0x3ffc63c0 0x400e4047:0x3ffc63e0 0x400e4b69:0x3ffc6430 0x400e3956:0x3ffc6490 0x400e37da:0x3ffc64e0 0x400e3873:0x3ffc6500 0x400e38be:0x3ffc6520 0x400e10a4:0x3ffc6540 0x400e1053:0x3ffc6560 0x400d1b7a:0x3ffc6590I am using the ESP-WROOM-32.
