Creating interrupt to a specific core
Foxtrot813
Postby Foxtrot813 » Sun Apr 29, 2018 3:49 am
Hi all,
I'm trying to discover if there is a way to pin an interrupt to a specific core, but I'm not finding much information about that. Say I have this timer interrupt configured:
static void initTimerGroup0(int timer_idx, bool auto_reload, double timer_interval_sec)
	timer_config_t config;
	config.divider = TIMER_DIVIDER;
	config.counter_dir = TIMER_COUNT_UP;
	config.counter_en = TIMER_PAUSE;
	config.alarm_en = TIMER_ALARM_EN;
	config.intr_type = TIMER_INTR_LEVEL;
	config.auto_reload = auto_reload;
	timer_init(TIMER_GROUP_0, timer_idx, &config);
	timer_set_counter_value(TIMER_GROUP_0, timer_idx, 0x00000000ULL);
	timer_set_alarm_value(TIMER_GROUP_0, timer_idx, timer_interval_sec*TIMER_SCALE);
	timer_enable_intr(TIMER_GROUP_0, timer_idx);
	timer_isr_register(TIMER_GROUP_0, timer_idx, adcGetRaw, (void *)timer_idx, ESP_INTR_FLAG_IRAM, NULL);
	timer_start(TIMER_GROUP_0, timer_idx);
Is there a way to attach it to core 1 or core 0? If not, how may I know on which CPU this interrupt will execute?
chegewara
Re: Creating interrupt to a specific core
Postby chegewara » Sun Apr 29, 2018 12:35 pm
http://esp-idf.readthedocs.io/en/latest ... r_handle_t
http://esp-idf.readthedocs.io/en/latest ... _sharediib
The interrupt will always be allocated on the core that runs this function.
And you can create task pinned to core.
fly135
Postby fly135 » Sun Apr 29, 2018 4:55 pm
Just make sure the task that allocated the interrupt is pinned to the core that you want the interrupt to occur on.
John A
Foxtrot813
Postby Foxtrot813 » Sun Apr 29, 2018 5:50 pm
Thanks guys, it worked. There's more interrupt manipulation than I thought, and from what I read, it's always advisable to create interrupt in a task pinned to a specific core....
Users browsing this forum: Bing [Bot] and 0 guests
