Page 1 of 2
[Solved]UART rx ISR not working
Posted: Sat May 05, 2018 6:53 pm
by blackpearl21
i am trying to work with UART on esp32, using esp-idf. i modified UART event sample code so that i can register UART IRQ routine and receive data directly, below is modified code,
void app_main()
    esp_log_level_set(TAG, ESP_LOG_INFO);
    /* Configure parameters of an UART driver,
     * communication pins and install the driver */
    uart_config_t uart_config = {
        .baud_rate = 115200,
        .data_bits = UART_DATA_8_BITS,
        .parity = UART_PARITY_DISABLE,
        .stop_bits = UART_STOP_BITS_1,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE
    uart_param_config(EX_UART_NUM, &uart_config);
    //Set UART log level
    //Set UART pins (using UART0 default pins ie no changes.)
    uart_set_pin(EX_UART_NUM, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
    //Install UART driver, and get the queue.
    uart_driver_install(EX_UART_NUM, BUF_SIZE * 2, 0, 0, NULL, 0);
//    //Set uart pattern detect function.
//    uart_enable_pattern_det_intr(EX_UART_NUM, '+', PATTERN_CHR_NUM, 10000, 10, 10);
//    //Reset the pattern queue length to record at most 20 pattern positions.
//    uart_pattern_queue_reset(EX_UART_NUM, 20);
	// Register ISR routine for RX interrupt
    uart_isr_register(EX_UART_NUM,uart_intr_handle, NULL, ESP_INTR_FLAG_LOWMED, handle_console);
    uart_enable_rx_intr(EX_UART_NUM);
    //Create a task to handler UART event from ISR
    //xTaskCreate(uart_event_task, "uart_event_task", 2048, NULL, 12, NULL);
// --- UART ISR Routine
static void IRAM_ATTR uart_intr_handle()
	uart_write_bytes(EX_UART_NUM, (const char*) "RX Done", 7);
i got this code from this FORUM, however mine is not working, i don't receive anything, as you can see i have written UART_Write on invoking of interrupt routine, but it doesnt work.
i would like to know whats wrong with this code.
Thanks Sushant
Re: UART rx ISR not working
Posted: Sun May 06, 2018 1:03 am
by kolban
I would first recommend that you rework your code to check the return codes from all the ESP32 functions and validate that they are all returning ESP_OK and, if not, what code they are returning.
Posted: Sun May 06, 2018 4:38 am
by blackpearl21
Thank your for reply and your time,
uart_isr_register, returns ESP_FAIL, error code is 0x105
ESP_ERROR_CHECK failed: esp_err_t 0x105 at 0x400d23e9
file: "C:/esp32/esp-idf/examples/peripherals/uart_events/main/uart_events_example_main.c" line 152
func: app_main
expression: uart_isr_register(EX_UART_NUM,uart_intr_handle, NULL, ESP_INTR_FLAG_LOWMED, handle_console)
As per definition its
#define ESP_ERR_NOT_FOUND 0x105,
however i dont understand what is NOT FOUND error.
Posted: Sun May 06, 2018 4:44 am
by kolban
In your code snippet, I think you are saying that this call is failing:
In the snippet, you didn't show what the value of EX_UART_NUM was nor did we see the definition of "handle_console".
Posted: Sun May 06, 2018 5:06 am
by blackpearl21
Sorry for inconvenience, the complete code is as below,
/* UART Events Example
   This example code is in the Public Domain (or CC0 licensed, at your option.)
   Unless required by applicable law or agreed to in writing, this
   software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
   CONDITIONS OF ANY KIND, either express or implied.
#include <stdio.h>
#include <string.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "driver/uart.h"
#include "esp_log.h"
static const char *TAG = "uart_events";
 * This example shows how to use the UART driver to handle special UART events.
 * It also reads data from UART0 directly, and echoes it to console.
 * - Port: UART0
 * - Receive (Rx) buffer: on
 * - Transmit (Tx) buffer: off
 * - Flow control: off
 * - Event queue: on
 * - Pin assignment: TxD (default), RxD (default)
#define EX_UART_NUM UART_NUM_0
#define PATTERN_CHR_NUM    (3)         /*!< Set the number of consecutive and identical characters received by receiver which defines a UART pattern*/
#define BUF_SIZE (1024)
#define RD_BUF_SIZE (BUF_SIZE)
static QueueHandle_t uart0_queue;
uart_isr_handle_t *handle_console;
static void uart_event_task(void *pvParameters)
    uart_event_t event;
    size_t buffered_size;
    uint8_t* dtmp = (uint8_t*) malloc(RD_BUF_SIZE);
    for(;;) {
        //Waiting for UART event.
        if(xQueueReceive(uart0_queue, (void * )&event, (portTickType)portMAX_DELAY)) {
            bzero(dtmp, RD_BUF_SIZE);
            ESP_LOGI(TAG, "uart[%d] event:", EX_UART_NUM);
            switch(event.type) {
                //Event of UART receving data
                /*We'd better handler data event fast, there would be much more data events than
                other types of events. If we take too much time on data event, the queue might
                be full.*/
                case UART_DATA:
                    ESP_LOGI(TAG, "[UART DATA]: %d", event.size);
                    uart_read_bytes(EX_UART_NUM, dtmp, event.size, portMAX_DELAY);
                    ESP_LOGI(TAG, "[DATA EVT]:");
                    uart_write_bytes(EX_UART_NUM, (const char*) dtmp, event.size);
                    break;
                //Event of HW FIFO overflow detected
                case UART_FIFO_OVF:
                    ESP_LOGI(TAG, "hw fifo overflow");
                    // If fifo overflow happened, you should consider adding flow control for your application.
                    // The ISR has already reset the rx FIFO,
                    // As an example, we directly flush the rx buffer here in order to read more data.
                    uart_flush_input(EX_UART_NUM);
                    xQueueReset(uart0_queue);
                    break;
                //Event of UART ring buffer full
                case UART_BUFFER_FULL:
                    ESP_LOGI(TAG, "ring buffer full");
                    // If buffer full happened, you should consider encreasing your buffer size
                    break;
                //Event of UART RX break detected
                case UART_BREAK:
                    ESP_LOGI(TAG, "uart rx break");
                    break;
                //Event of UART parity check error
                case UART_PARITY_ERR:
                    ESP_LOGI(TAG, "uart parity error");
                    break;
                //Event of UART frame error
                case UART_FRAME_ERR:
                    ESP_LOGI(TAG, "uart frame error");
                    break;
                //UART_PATTERN_DET
                case UART_PATTERN_DET:
                    uart_get_buffered_data_len(EX_UART_NUM, &buffered_size);
                    int pos = uart_pattern_pop_pos(EX_UART_NUM);
                    ESP_LOGI(TAG, "[UART PATTERN DETECTED] pos: %d, buffered size: %d", pos, buffered_size);
                    if (pos == -1) {
                        // There used to be a UART_PATTERN_DET event, but the pattern position queue is full so that it can not
                        // record the position. We should set a larger queue size.
                        // As an example, we directly flush the rx buffer here.
                    } else {
                        uart_read_bytes(EX_UART_NUM, dtmp, pos, 100 / portTICK_PERIOD_MS);
                        uint8_t pat[PATTERN_CHR_NUM + 1];
                        memset(pat, 0, sizeof(pat));
                        uart_read_bytes(EX_UART_NUM, pat, PATTERN_CHR_NUM, 100 / portTICK_PERIOD_MS);
                        ESP_LOGI(TAG, "read data: %s", dtmp);
                        ESP_LOGI(TAG, "read pat : %s", pat);
                    break;
                //Others
                default:
                    ESP_LOGI(TAG, "uart event type: %d", event.type);
                    break;
    free(dtmp);
    dtmp = NULL;
    vTaskDelete(NULL);
void app_main()
	int ret;
    ESP_ERROR_CHECK(uart_param_config(EX_UART_NUM, &uart_config));
    ESP_ERROR_CHECK(uart_set_pin(EX_UART_NUM, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE));
    ESP_ERROR_CHECK(uart_driver_install(EX_UART_NUM, BUF_SIZE * 2, 0, 0, NULL, 0));
    ESP_ERROR_CHECK(uart_isr_register(EX_UART_NUM,uart_intr_handle, NULL, ESP_INTR_FLAG_LOWMED, handle_console));
    //ESP_LOGI(TAG, "Return from UART ISR %X", ret);
    ESP_ERROR_CHECK(uart_enable_rx_intr(EX_UART_NUM));
it was working example of UART_EVENTS, i modified it for ISR routine, i didnt change much.
added these 2 lines
EDITS: earlier post was trial and error for argument,edited for original.
ESP_ERROR_CHECK(uart_isr_register(EX_UART_NUM,uart_intr_handle, argISR, ESP_INTR_FLAG_LOWMED, handle_console));
Posted: Sun May 06, 2018 5:28 am
by kolban
Just a guess, but if I am reading your code correctly, we have:
I can't help wondering if the following might not be the correct pattern:
uart_isr_handle_t handle_console;
uart_isr_register(EX_UART_NUM,uart_intr_handle, NULL, ESP_INTR_FLAG_LOWMED, &handle_console)
Posted: Sun May 06, 2018 6:05 am
by blackpearl21
Sorry didnt help,
ESP_ERROR_CHECK failed: esp_err_t 0x105 at 0x400d23e1
func: app_main
expression: uart_isr_register(EX_UART_NUM,uart_intr_handle, NULL, ESP_INTR_FLAG_LOWMED, &handle_console)
Shouldn't this &handle_console be a double pointer ?
Posted: Sun May 06, 2018 6:16 am
by chegewara
Im not sure you can use UART0, its serial port used to debug.
Like kolban said its better to use this line that way:
static uart_isr_handle_t handle_console;
ESP_ERROR_CHECK(uart_isr_register(EX_UART_NUM,uart_intr_handle, NULL, ESP_INTR_FLAG_LOWMED, &handle_console));
or you have to initialize *handle_console before you can use it.
Posted: Sun May 06, 2018 6:35 am
by blackpearl21
Thank you for reply and your time,
Why static, its already a global definition, and if it is defined in another file shouldnt compilation error be thown ?
ERROR has changed now
ESP_ERROR_CHECK failed: esp_err_t 0x102 at 0x400d23e3
file: "C:/esp32/esp-idf/examples/peripherals/uart_events/main/uart_events_example_main.c" line 155
func: app_main
expression: uart_isr_register(EX_UART_NUM,uart_intr_handle, NULL, ESP_INTR_FLAG_HIGH, &handle_console)
Backtrace: 0x40087510:0x3ffb4670 0x400879a1:0x3ffb4690 0x400d23e3:0x3ffb46b0 0x400d09f6:0x3ffb46f0
Complete code,
#include <stdio.h>
#include <string.h>
 * - Port: UART0
 * - Event queue: on
uint8_t argISR;
    uart_event_t event;
    for(;;) {
                be full.*/
                case UART_DATA:
                    break;
                case UART_FIFO_OVF:
                    break;
                    break;
                case UART_BREAK:
                    break;
                    break;
                    break;
                //UART_PATTERN_DET
                    if (pos == -1) {
                    } else {
                    break;
                //Others
                default:
                    break;
    free(dtmp);
    dtmp = NULL;
    vTaskDelete(NULL);
void app_main()
	int ret;
    ESP_ERROR_CHECK(uart_isr_register(EX_UART_NUM,uart_intr_handle, NULL, ESP_INTR_FLAG_HIGH, &handle_console));
Posted: Sun May 06, 2018 2:47 pm
by chegewara
Time to learn how to use GDB to translate this:
into something more human readable or use this tool:
https://github.com/me-no-dev/EspExceptionDecoder
