Problem connected to a server with authentication keyin arduino framework.
trix37
Postby trix37 » Wed May 16, 2018 3:26 pm
Hi, I am trying to connect to a web server using the code below:
WiFiClient client;
  //Connect to the server
  if (!client.connect("http://[url]/test/test?api_key=[key]", clientPort)) {
    Serial.println("connection failed");
    return;
Key is the authentication key of the server. I am getting "connection failed". Is there a way to implement this?
