MQTT SSL Library
borch84
MQTT SSL Library
Postby borch84 » Fri May 18, 2018 4:30 am
Hi Community,
I am trying to add MQTT Secure Client connectivity to my ESP32. Do you know which MQTT library I can use with SSL capability ? My MQTT broker uses certificates to establish the connection. I was able to use the WifiClientSecure.h and Adafruit MQTT library using the Arduino IDE. I was wondering if I can use those libraries in the GATT Client in order to add WiFi + MQTT features. Thank you.
loboris
Re: MQTT SSL Library
Postby loboris » Fri May 18, 2018 5:52 am
euripedes
Postby euripedes » Fri May 18, 2018 11:25 am
I did an integration of Paho MQTT recently for internal use, no open source sorry.
https://github.com/eclipse/paho.mqtt.embedded-c
It was not hard to integrate with mbedtls.
borch84
Postby borch84 » Fri May 18, 2018 6:32 pm
Thank you, I am going to take a look. Regards.
borch84
Postby borch84 » Sat May 19, 2018 8:10 pm
I confirm I was able to use tuanpmt's mqtt_ssl with my mqtt broker. Thank you.
Users browsing this forum: ChatGPT-User, Google [Bot], Semrush [Bot] and 2 guests
