Sigma-delta or Led Channel (PWM)? Which is better?
JoaoLopesF
Postby JoaoLopesF » Fri May 18, 2018 8:23 pm
I'm working on a project. This have 8 channels (Sigma-Delta ou LedC) of ESP32 connected to leds.
Frequencies of blink can vary from 0.2 to 50 Hz (ussually 0.5 to 20 Hz).
I did work with both types (by #define):
- With sigma-delta
- With Led channel
Technically sigma-delta is better than PWM (LedC), is this correct?
Questions from a beginner in sigma-delta?
- Is the capacitor needed to plug leds ?
f you add a capacitor between the output pin and ground, the average output voltage will be Vdc = VDDIO / 256 * duty + VDDIO/2, where VDDIO is the power supply voltage.
- Why the range recommended is:
recommended range is -90 ~ 90
Archibald
Re: Sigma-delta or Led Channel (PWM)? Which is better?
Postby Archibald » Sun May 20, 2018 1:03 am
As far as I'm aware, LEDC can flash an LED only down to 1 Hz.
It sounds like you need to drive the outputs directly from code especially if you wish to drive the 8 outputs in a sequence.
Beware of photosensitive epilepsy (link).
Regarding . . . .
If you add a capacitor between the output pin and ground, the average output voltage will be Vdc = VDDIO / 256 * duty + VDDIO/2, where VDDIO is the power supply voltage.
. . . . in my view it is inadvisable to connect a capacitor between output pin and ground without a series resistor.
JoaoLopesF
Postby JoaoLopesF » Tue May 22, 2018 2:35 pm
Archibald,
I knew this, your advice is true for avoid problems with epileptics
This is true to me too
Thanks for your response
Deouss
Postby Deouss » Tue May 22, 2018 3:25 pm
Or use Remote Control feature.
It has 8 channels exactly as you need and allows smaller frequencies too
I think that would be perfect solution here
JoaoLopesF
Postby JoaoLopesF » Mon May 28, 2018 8:59 pm
Hi, Deouss, tanks for response
How use Remote Control feature (RMT) to control brightness of leds ?
Deouss
Postby Deouss » Tue May 29, 2018 1:30 am
Look at the rmt example included with esp-idf. All you need is to set up the transmission channel and control the transmitted waveform that you amplify to your leds.
JoaoLopesF
Postby JoaoLopesF » Tue May 29, 2018 9:36 pm
Hi Deouss , I do this, thanks a lot
I see that top Arduino libraries for Leds, as FastLed, using RMT in Esp32, why not Sigma or Led Channel ?
Users browsing this forum: Bing [Bot], Bytespider, Semrush [Bot] and 2 guests
