How to create and build a standalone ESP-IDF static library?
haxpanel
Postby haxpanel » Mon May 21, 2018 5:12 pm
I'm learning ESP-IDF platform and now want to create a library in order to be able to structure my code properly in the future.
I've done some research and found out that a component needs to be under a `components/<component-name>` folder. The documentation doesn't talk about or I missed how to create a standalone component and how to compile it to a static library, into a `.a` file which later can be linked to different projects.
- What is the minimum configuration for an ESP-IDF static library that can be built into a `.a` file?
- How to compile a component into a standalone static library?
ESP_Angus
Re: How to create and build a standalone ESP-IDF static library?
Postby ESP_Angus » Mon May 21, 2018 11:12 pm
I'm going to copy the answer from the github issue to start with. Let me know if you'd like me to expand on or explain anything else from this answer:
For structure & modularity, IDF has the concept of "components". Each component is built into a static library as part of the build process.
The smallest possible component would contain one source file only, as well as a component.mk file to define the component and describe the location of that source file.
You can find documentation about the build system and creating components here:
https://esp-idf.readthedocs.io/en/lates ... ystem.html
Users browsing this forum: kurta999 and 17 guests
