need recommendation for WiFi antenna
Posted: Wed May 23, 2018 9:07 pm
by mzimmers
Hi, all -
My company is looking into building a product based on the ESP32 module. We began with the WROOM, but we're concerned about whether the integrated antenna will give us adequate range. So, we're considering using the WROVER-I and an external antenna. Does anyone have a recommendation for an antenna for use with this module?
Thanks.
Re: need recommendation for WiFi antenna
Posted: Wed May 30, 2018 6:36 pm
by mzimmers
Hmm...no responses. OK, then let me ask this: is anyone aware of a spec (or guidelines) for the selection of a compatible antenna?
Thanks...
Posted: Wed May 30, 2018 7:35 pm
by loboris
Why selecting an external wifi antenna for WROVER-I would be any different then selecting the antenna for any other wifi device ?
Posted: Wed May 30, 2018 8:18 pm
by mzimmers
It might not be. Some people have told me, though, that there's a certain art to matching antennas to WiFi modules, and I just wanted to know what anyone else had done. My early indications are the antennas I bought to test with aren't doing much, but there's a lot of unknowns at this point.
Posted: Thu May 31, 2018 12:49 pm
by Deouss
buy antenna tester
Posted: Thu May 31, 2018 3:35 pm
by chrismerck
Good question. Yes there's a bit of an art to antenna matching, but the good news is, ESP32 is no different than any other WiFi device.
You need to be concerned with two things: impedance matching, and antenna frequency range. WiFi+BLE frequency range is common world-wide, and the ESP32 uses a 50-ohm impedence on the antenna output, which is also the standard.
So, any 50-ohm antenna with an appropriate connector (such as UFL for WROOM-32U) will work. Example: https://www.digikey.com/product-detail/ ... ND/2267896
Hope that helps.
Posted: Fri Jun 01, 2018 3:24 pm
by mzimmers
Hi Chris -
Thanks for the information. I've discovered that most of the antennas that meet our size requirements are of very little gain (1-2 dBi) so we'll probably just stick with the integrated antenna. (I tried a couple external antennas, with no noticeable improvement, though I didn't remove the integrated antenna, so that might have messed things up.) I appreciate your feedback.
Posted: Fri Jun 01, 2018 7:21 pm
by Archibald
I've discovered that most of the antennas that meet our size requirements are of very little gain (1-2 dBi) . . . .
ESP32 modules may not have such a good radiation pattern as omnidirectional aerials.
Posted: Wed Jun 06, 2018 2:29 pm
by chrismerck
Higher gain means higher directivity. That's only a good thing if you can control the direction the antenna points. You can look at polar plots of the radiation pattern in the specs for an antenna you are considering.
An "ideal" antenna for portable / uncontrolled orientation use would be 0dBi -- also known as "isotropic", that is, radiate evenly in all directions.
