BT: bta_gattc_co_cache_addr_init, Line = 333, nvs flash get blob data fail, err_code = 110c
borch84
Postby borch84 » Thu May 24, 2018 3:04 am
Hi I am getting a BT error.
First I initialize wifi, second mqtt client, and then the bluetooth in order to read an itag's ble address and send that address to a mqtt broker. However after initializing the mqtt client I got this message:
E (3324) BT: bta_gattc_co_cache_addr_init, Line = 333, nvs flash get blob data fail, err_code = 110c
* This file is for gatt client. It can scan ble device, connect one device.
* Run the gatt_server demo, the client demo will automatically connect to the gatt_server demo.
* Client demo will enable gatt_server's notify after connection. Then the two devices will exchange
* data.
#ifndef BTM_INITIAL_TRACE_LEVEL
#define BTM_INITIAL_TRACE_LEVEL BT_TRACE_LEVEL_DEBUG
#endif
#ifndef L2CAP_INITIAL_TRACE_LEVEL
#define L2CAP_INITIAL_TRACE_LEVEL BT_TRACE_LEVEL_DEBUG
#endif
#ifndef GATT_INITIAL_TRACE_LEVEL
#define GATT_INITIAL_TRACE_LEVEL BT_TRACE_LEVEL_DEBUG
#endif
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <stdio.h>
#include "nvs.h"
#include "nvs_flash.h"
#include "controller.h"
#include "esp_bt.h"
#include "esp_gap_ble_api.h"
#include "esp_gattc_api.h"
#include "esp_gatt_defs.h"
#include "esp_bt_main.h"
#include "esp_gatt_common_api.h"
//Wifi Section
#include "esp_wifi.h"
#include "esp_system.h"
#include "esp_event_loop.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "freertos/queue.h"
#include "lwip/sockets.h"
#include "lwip/dns.h"
#include "lwip/netdb.h"
#include "esp_log.h"
#include "mqtt_client.h"
static EventGroupHandle_t wifi_event_group;
const static int CONNECTED_BIT = BIT0;
static const char *MQTT_TAG = "MQTTS";
static const char *WIFI_TAG = "WiFi";
static esp_err_t wifi_event_handler(void *ctx, system_event_t *event)
    switch (event->event_id) {
        case SYSTEM_EVENT_STA_START:
            esp_wifi_connect();
        case SYSTEM_EVENT_STA_GOT_IP:
            xEventGroupSetBits(wifi_event_group, CONNECTED_BIT);
        case SYSTEM_EVENT_STA_DISCONNECTED:
            esp_wifi_connect();
            xEventGroupClearBits(wifi_event_group, CONNECTED_BIT);
        default:
    return ESP_OK;
static void wifi_init(void)
    tcpip_adapter_init();
    wifi_event_group = xEventGroupCreate();
    ESP_ERROR_CHECK(esp_event_loop_init(wifi_event_handler, NULL));
    ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = "Raspberrypi", //borch
            .password = "XXX", //borch
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config));
    ESP_LOGI(WIFI_TAG, "start the WIFI SSID:[%s] password:[%s]", "Raspberrypi", "******");
    ESP_ERROR_CHECK(esp_wifi_start());
    ESP_LOGI(WIFI_TAG, "Waiting for wifi");
    xEventGroupWaitBits(wifi_event_group, CONNECTED_BIT, false, true, portMAX_DELAY);
//End Wifi Section
//mqtt section starts here
static esp_err_t mqtt_event_handler(esp_mqtt_event_handle_t event)
    esp_mqtt_client_handle_t mqtt_client = event->client;
    int msg_id;
    // your_context_t *context = event->context;
        case MQTT_EVENT_CONNECTED:
            ESP_LOGI(MQTT_TAG, "MQTT_EVENT_CONNECTED");
            msg_id = esp_mqtt_client_subscribe(mqtt_client, "esp32/ble", 0);
            ESP_LOGI(MQTT_TAG, "sent subscribe successful, msg_id=%d", msg_id);
            //msg_id = esp_mqtt_client_subscribe(mqtt_client, "/topic/qos1", 1);
            //ESP_LOGI(MQTT_TAG, "sent subscribe successful, msg_id=%d", msg_id);
            //msg_id = esp_mqtt_client_unsubscribe(mqtt_client, "/topic/qos1");
            //ESP_LOGI(MQTT_TAG, "sent unsubscribe successful, msg_id=%d", msg_id);
        case MQTT_EVENT_DISCONNECTED:
            ESP_LOGI(MQTT_TAG, "MQTT_EVENT_DISCONNECTED");
        case MQTT_EVENT_SUBSCRIBED:
            ESP_LOGI(MQTT_TAG, "MQTT_EVENT_SUBSCRIBED, msg_id=%d", event->msg_id);
            msg_id = esp_mqtt_client_publish(mqtt_client, "esp32/ble", "data from esp32 gatt wifi mqtt_ssl example", 0, 0, 0);
            ESP_LOGI(MQTT_TAG, "sent publish successful, msg_id=%d", msg_id);
        case MQTT_EVENT_UNSUBSCRIBED:
            ESP_LOGI(MQTT_TAG, "MQTT_EVENT_UNSUBSCRIBED, msg_id=%d", event->msg_id);
        case MQTT_EVENT_PUBLISHED:
            ESP_LOGI(MQTT_TAG, "MQTT_EVENT_PUBLISHED, msg_id=%d", event->msg_id);
        case MQTT_EVENT_DATA:
            ESP_LOGI(MQTT_TAG, "MQTT_EVENT_DATA");
            printf("TOPIC=%.*s\r\n", event->topic_len, event->topic);
            printf("DATA=%.*s\r\n", event->data_len, event->data);
        case MQTT_EVENT_ERROR:
            ESP_LOGI(MQTT_TAG, "MQTT_EVENT_ERROR");
    return ESP_OK;
const char* raspberrypi_pem=\
//next server certificate of my raspberrypi 192_mqtt_srv.crt
"-----BEGIN CERTIFICATE-----\n"\
"MIIDlDCCAnwCCQDokqMaDCZuYzANBgkqhkiG9w0BAQsFADCBizELMAkGA1UEBhMC\n"\
"/wNyf821mrUkNOqo8yH1KN21qJkJQb3hbbmHlEuw2DSKdMAZDTDb7NcH89kYPVWf\n"\
"b+jcOvfgFW8=\n"\
"-----END CERTIFICATE-----\n"\
//next server key from my pi 192_mqtt_server.key
"-----BEGIN RSA PRIVATE KEY-----\n"\
"MIIEogIBAAKCAQEAxnBrr2URRKS4qTlBW1nq4hW3/DOC51ukUZVKCg4w8B8uhWgB\n"\
"vm4b5eTD59jUGQMMT66wiSUc0VaPeFkWZc6H48aLBkih0QljoMGA5udejXCZoMIU\n"\
"xtg+Elmrwp+6Li/BjtpLie+xJYHWFRwqk+NupXzLiIz/F+VULtY=\n"\
"-----END RSA PRIVATE KEY-----\n"\
// The Root CA certificate is the last certificate in the list of certificates printed.
//next CA root certificate from my raspberrypi: 192_mqtt_ca.crt
"-----BEGIN CERTIFICATE-----\n" \
"MIID7jCCAtagAwIBAgIJALRpVJTQuFNvMA0GCSqGSIb3DQEBCwUAMIGLMQswCQYD\n"\
"2w3jmt1V5v9HsST/CYoBzAgMe9oylpr7miJF1e1iB3tdNTGqrprZAi+wMWydHTDc\n"\
"do0=\n"\
"-----END CERTIFICATE-----\n";
static void mqtt_app_start(void)
    const esp_mqtt_client_config_t mqtt_cfg = {
        .uri = "mqtts://192.168.0.16:8883", //borch
        .event_handle = mqtt_event_handler,
        //.cert_pem = (const char *)iot_eclipse_org_pem_start,
        .cert_pem = raspberrypi_pem, //borch
        .username = "mqtt_user", //borch
        .password = "mqtt_pass01", //borch
        .client_id = "esp32_gatt_wifi_mqtt_ssl_client", //borch
        .transport = MQTT_TRANSPORT_OVER_SSL, //borch
    ESP_LOGI(MQTT_TAG, "[APP] Free memory: %d bytes", esp_get_free_heap_size());
    esp_mqtt_client_handle_t mqtt_client = esp_mqtt_client_init(&mqtt_cfg);
    esp_mqtt_client_start(mqtt_client);
// end mqtt section
#define GATTC_TAG "GATTC_DEMO"
#define REMOTE_SERVICE_UUID        0x180F //iTAG battery service
#define REMOTE_NOTIFY_CHAR_UUID    0x2A19 //battery level characteristic
#define PROFILE_NUM      1
#define PROFILE_A_APP_ID 0
#define INVALID_HANDLE   0
//static const char remote_device_name[] = "ESP_GATTS_DEMO";
static const char remote_device_name[] = "iTAG"; //borch
static bool conn    = false;
static bool get_server = false;
static esp_gattc_char_elem_t *char_elem_result   = NULL;
static esp_gattc_descr_elem_t *descr_elem_result = NULL;
/* eclare static functions */
static void esp_gap_cb(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param);
static void esp_gattc_cb(esp_gattc_cb_event_t event, esp_gatt_if_t gattc_if, esp_ble_gattc_cb_param_t *param);
static void gattc_profile_event_handler(esp_gattc_cb_event_t event, esp_gatt_if_t gattc_if, esp_ble_gattc_cb_param_t *param);
//Wifi Section
//End Wifi Section
static esp_bt_uuid_t remote_filter_service_uuid = {
    .len = ESP_UUID_LEN_16,
    .uuid = {.uuid16 = REMOTE_SERVICE_UUID,},
static esp_bt_uuid_t remote_filter_char_uuid = {
    .uuid = {.uuid16 = REMOTE_NOTIFY_CHAR_UUID,},
static esp_bt_uuid_t notify_descr_uuid = {
    .uuid = {.uuid16 = ESP_GATT_UUID_CHAR_CLIENT_CONFIG,},
static esp_ble_scan_params_t ble_scan_params = {
    .scan_type              = BLE_SCAN_TYPE_ACTIVE,
    .own_addr_type          = BLE_ADDR_TYPE_PUBLIC,
    .scan_filter_policy     = BLE_SCAN_FILTER_ALLOW_ALL,
    .scan_interval          = 0x50,
    .scan_window            = 0x30
struct gattc_profile_inst {
    esp_gattc_cb_t gattc_cb;
    uint16_t gattc_if;
    uint16_t app_id;
    uint16_t conn_id;
    uint16_t service_start_handle;
    uint16_t service_end_handle;
    uint16_t char_handle;
    esp_bd_addr_t remote_bda;
/* One gatt-based profile one app_id and one gattc_if, this array will store the gattc_if returned by ESP_GATTS_REG_EVT */
static struct gattc_profile_inst gl_profile_tab[PROFILE_NUM] = {
    [PROFILE_A_APP_ID] = {
        .gattc_cb = gattc_profile_event_handler,
        .gattc_if = ESP_GATT_IF_NONE,       /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */
    esp_ble_gattc_cb_param_t *p_data = (esp_ble_gattc_cb_param_t *)param;
    switch (event) {
    case ESP_GATTC_REG_EVT:
        ESP_LOGI(GATTC_TAG, "REG_EVT");
        esp_err_t scan_ret = esp_ble_gap_set_scan_params(&ble_scan_params);
        if (scan_ret){
            ESP_LOGE(GATTC_TAG, "set scan params error, error code = %x", scan_ret);
    case ESP_GATTC_CONNECT_EVT:{
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_CONNECT_EVT conn_id %d, if %d", p_data->connect.conn_id, gattc_if);
        gl_profile_tab[PROFILE_A_APP_ID].conn_id = p_data->connect.conn_id;
        memcpy(gl_profile_tab[PROFILE_A_APP_ID].remote_bda, p_data->connect.remote_bda, sizeof(esp_bd_addr_t));
        ESP_LOGI(GATTC_TAG, "REMOTE BDA:");
        esp_log_buffer_hex(GATTC_TAG, gl_profile_tab[PROFILE_A_APP_ID].remote_bda, sizeof(esp_bd_addr_t));
        esp_err_t mtu_ret = esp_ble_gattc_send_mtu_req (gattc_if, p_data->connect.conn_id);
        if (mtu_ret){
            ESP_LOGE(GATTC_TAG, "config MTU error, error code = %x", mtu_ret);
    case ESP_GATTC_OPEN_EVT:
        if (param->open.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "open failed, status %d", p_data->open.status);
        ESP_LOGI(GATTC_TAG, "open success");
    case ESP_GATTC_CFG_MTU_EVT:
        if (param->cfg_mtu.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG,"config mtu failed, error status = %x", param->cfg_mtu.status);
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_CFG_MTU_EVT, Status %d, MTU %d, conn_id %d", param->cfg_mtu.status, param->cfg_mtu.mtu, param->cfg_mtu.conn_id);
        esp_ble_gattc_search_service(gattc_if, param->cfg_mtu.conn_id, &remote_filter_service_uuid);
    case ESP_GATTC_SEARCH_RES_EVT: {
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_SEARCH_RES_EVT");
        esp_gatt_srvc_id_t *srvc_id =(esp_gatt_srvc_id_t *)&p_data->search_res.srvc_id;
        if (srvc_id->id.uuid.len == ESP_UUID_LEN_16 && srvc_id->id.uuid.uuid.uuid16 == REMOTE_SERVICE_UUID) {
            ESP_LOGI(GATTC_TAG, "service found");
            get_server = true;
            gl_profile_tab[PROFILE_A_APP_ID].service_start_handle = p_data->search_res.start_handle;
            gl_profile_tab[PROFILE_A_APP_ID].service_end_handle = p_data->search_res.end_handle;
            ESP_LOGI(GATTC_TAG, "UUID16: %x", srvc_id->id.uuid.uuid.uuid16);
    case ESP_GATTC_SEARCH_CMPL_EVT:
        if (p_data->search_cmpl.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "search service failed, error status = %x", p_data->search_cmpl.status);
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_SEARCH_CMPL_EVT");
        if (get_server){
            uint16_t count = 0;
            esp_gatt_status_t status = esp_ble_gattc_get_attr_count( gattc_if,
        p_data->search_cmpl.conn_id,
        ESP_GATT_DB_CHARACTERISTIC,
        gl_profile_tab[PROFILE_A_APP_ID].service_start_handle,
        gl_profile_tab[PROFILE_A_APP_ID].service_end_handle,
        INVALID_HANDLE,
        &count);
            if (status != ESP_GATT_OK){
                ESP_LOGE(GATTC_TAG, "esp_ble_gattc_get_attr_count error");
            ESP_LOGI(GATTC_TAG, "attr count: %d\n",count);
            if (count > 0){
                char_elem_result = (esp_gattc_char_elem_t *)malloc(sizeof(esp_gattc_char_elem_t) * count);
                if (!char_elem_result){
                    ESP_LOGE(GATTC_TAG, "gattc no mem");
                }else{
                    status = esp_ble_gattc_get_char_by_uuid( gattc_if,
                                                             remote_filter_char_uuid,
                                                             char_elem_result,
                                                             &count);
                        ESP_LOGE(GATTC_TAG, "esp_ble_gattc_get_char_by_uuid error");
                    /*  Every service have only one char in our 'ESP_GATTS_DEMO' demo, so we used first 'char_elem_result' */
                    if (count > 0 && (char_elem_result[0].properties & ESP_GATT_CHAR_PROP_BIT_NOTIFY)){
                        ESP_LOGI(GATTC_TAG, "char count: %d\n",count);
                        gl_profile_tab[PROFILE_A_APP_ID].char_handle = char_elem_result[0].char_handle;
                        esp_ble_gattc_read_char(gattc_if,p_data->search_cmpl.conn_id,gl_profile_tab[PROFILE_A_APP_ID].char_handle,ESP_GATT_AUTH_REQ_NONE);
                        //esp_ble_gattc_register_for_notify (gattc_if, gl_profile_tab[PROFILE_A_APP_ID].remote_bda, char_elem_result[0].char_handle);
                /* free char_elem_result */
                free(char_elem_result);
            }else{
                ESP_LOGE(GATTC_TAG, "no char found");
    case ESP_GATTC_READ_CHAR_EVT: {
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_READ_CHAR_EVT");
        const char *char_pointer = (char*)p_data->read.value; //p_data->read.value: p_data is pointer of union type esp_ble_gattc_cb_param_t
                                                            //for accesing the read struc we need to use p_data->read.value sintaxis.
        //read member is a struct of type gattc_read_char_evt_param.
        //https://github.com/espressif/esp-idf/blob/a255622/components/bt/bluedroid/api/include/api/esp_gattc_api.h
        //https://stackoverflow.com/questions/16804650/accessing-c-union-members-via-pointers
        //https://www.tutorialspoint.com/cprogramming/c_unions.htm
        // p_data->read.value is a pointer to unit8_t type.
        //We need to convert from *unit8_t to *char https://stackoverflow.com/questions/12296984/c-uint8-datatype-conversion-to-const-char-datatype
        //When we have the pointer to char, we need to cast it int in order to read the numerical value of the iTag.
        //For example, p_data->read.value returns 'c' = 0x63 = 99
        int battery_percentage = (int)*char_pointer;
        ESP_LOGI(GATTC_TAG, "(p_data->read.value) Battery level: %d %%",battery_percentage); //https://stackoverflow.com/questions/1860159/how-to-escape-the-percent-sign-in-cs-printf
        ESP_LOGI(GATTC_TAG, "p_data->read.value_len %d",p_data->read.value_len);
        //int battery_percentage = atoi((const char*) p_data->read.value);
        //int battery_percentage = strtol((const char*)p_data->read.value, NULL, 10);
        //printf("Battery Level: %d ",battery_percentage);
    case ESP_GATTC_REG_FOR_NOTIFY_EVT: {
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_REG_FOR_NOTIFY_EVT");
        if (p_data->reg_for_notify.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "REG FOR NOTIFY failed: error status = %d", p_data->reg_for_notify.status);
        }else{
            uint16_t count = 0;
            uint16_t notify_en = 1;
            esp_gatt_status_t ret_status = esp_ble_gattc_get_attr_count( gattc_if,
        gl_profile_tab[PROFILE_A_APP_ID].conn_id,
        ESP_GATT_DB_DESCRIPTOR,
        &count);
            if (ret_status != ESP_GATT_OK){
            ESP_LOGI(GATTC_TAG, "desc count: %d\n",count);
            if (count > 0){
                descr_elem_result = malloc(sizeof(esp_gattc_descr_elem_t) * count);
                if (!descr_elem_result){
                    ESP_LOGE(GATTC_TAG, "malloc error, gattc no mem");
                }else{
                    ret_status = esp_ble_gattc_get_descr_by_char_handle( gattc_if,
        p_data->reg_for_notify.handle,
        notify_descr_uuid,
        descr_elem_result,
        &count);
                        ESP_LOGE(GATTC_TAG, "esp_ble_gattc_get_descr_by_char_handle error");
                    /* Every char has only one descriptor in our 'ESP_GATTS_DEMO' demo, so we used first 'descr_elem_result' */
                    if (count > 0 && descr_elem_result[0].uuid.len == ESP_UUID_LEN_16 && descr_elem_result[0].uuid.uuid.uuid16 == ESP_GATT_UUID_CHAR_CLIENT_CONFIG){
                        ret_status = esp_ble_gattc_write_char_descr( gattc_if,
        descr_elem_result[0].handle,
        sizeof(notify_en),
        (uint8_t *)&notify_en,
        ESP_GATT_WRITE_TYPE_RSP,
                        ESP_LOGE(GATTC_TAG, "esp_ble_gattc_write_char_descr error");
                    /* free descr_elem_result */
                    free(descr_elem_result);
            else{
                ESP_LOGE(GATTC_TAG, "decsr not found");
    case ESP_GATTC_NOTIFY_EVT:
        if (p_data->notify.is_notify){
            ESP_LOGI(GATTC_TAG, "ESP_GATTC_NOTIFY_EVT, receive notify value:");
        }else{
            ESP_LOGI(GATTC_TAG, "ESP_GATTC_NOTIFY_EVT, receive indicate value:");
        esp_log_buffer_hex(GATTC_TAG, p_data->notify.value, p_data->notify.value_len);
    case ESP_GATTC_WRITE_DESCR_EVT:
        if (p_data->write.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "write descr failed, error status = %x", p_data->write.status);
        ESP_LOGI(GATTC_TAG, "write descr success ");
        uint8_t write_char_data[35];
        for (int i = 0; i < sizeof(write_char_data); ++i)
            write_char_data[i] = i % 256;
        esp_ble_gattc_write_char( gattc_if,
                                  sizeof(write_char_data),
                                  write_char_data,
    case ESP_GATTC_SRVC_CHG_EVT: {
        esp_bd_addr_t bda;
        memcpy(bda, p_data->srvc_chg.remote_bda, sizeof(esp_bd_addr_t));
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_SRVC_CHG_EVT, bd_addr:");
        esp_log_buffer_hex(GATTC_TAG, bda, sizeof(esp_bd_addr_t));
    case ESP_GATTC_WRITE_CHAR_EVT:
            ESP_LOGE(GATTC_TAG, "write char failed, error status = %x", p_data->write.status);
        ESP_LOGI(GATTC_TAG, "write char success ");
    case ESP_GATTC_DISCONNECT_EVT:
        conn = false;
        get_server = false;
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_DISCONNECT_EVT, reason = %d", p_data->disconnect.reason);
    default:
    uint8_t *adv_name = NULL;
    uint8_t adv_name_len = 0;
    switch (event) {
    case ESP_GAP_BLE_SCAN_PARAM_SET_COMPLETE_EVT: {
        //the unit of the duration is second
        uint32_t duration = 30;
        esp_ble_gap_start_scanning(duration);
    case ESP_GAP_BLE_SCAN_START_COMPLETE_EVT:
        //scan start complete event to indicate scan start successfully or failed
        if (param->scan_start_cmpl.status != ESP_BT_STATUS_SUCCESS) {
            ESP_LOGE(GATTC_TAG, "scan start failed, error status = %x", param->scan_start_cmpl.status);
        ESP_LOGI(GATTC_TAG, "scan start success");
    case ESP_GAP_BLE_SCAN_RESULT_EVT: {
        esp_ble_gap_cb_param_t *scan_result = (esp_ble_gap_cb_param_t *)param;
        switch (scan_result->scan_rst.search_evt) {
        case ESP_GAP_SEARCH_INQ_RES_EVT:
            esp_log_buffer_hex(GATTC_TAG, scan_result->scan_rst.bda, 6);
            ESP_LOGI(GATTC_TAG, "searched Adv Data Len %d, Scan Response Len %d", scan_result->scan_rst.adv_data_len, scan_result->scan_rst.scan_rsp_len);
            adv_name = esp_ble_resolve_adv_data(scan_result->scan_rst.ble_adv,
                                                ESP_BLE_AD_TYPE_NAME_CMPL, &adv_name_len);
            ESP_LOGI(GATTC_TAG, "searched Device Name Len %d", adv_name_len);
            esp_log_buffer_char(GATTC_TAG, adv_name, adv_name_len);
            ESP_LOGI(GATTC_TAG, "\n");
            if (adv_name != NULL) {
                char adv_name_nospaces[strlen(remote_device_name)];
                int i,j;
                for ( i = 0, j = 0; i<strlen((const char*)adv_name);i++,j++) {
                    if (adv_name[i] != ' ')
                        adv_name_nospaces[j]=adv_name[i];
                    else
                        j--;
                adv_name_nospaces[j]=0;
                ESP_LOGI(GATTC_TAG, "remote_device_name: %s | remote_device_name len: %d\n", remote_device_name,strlen(remote_device_name));
                ESP_LOGI(GATTC_TAG, "adv_name_nospaces: %s | adv_name_nospaces len: %d\n", adv_name_nospaces,strlen(adv_name_nospaces));
                //if (strlen(remote_device_name) == adv_name_len && strncmp((char *)adv_name, remote_device_name, adv_name_len) == 0) {
                if ( strncmp(adv_name_nospaces, remote_device_name, strlen(adv_name_nospaces)) == 0 ) {
                    ESP_LOGI(GATTC_TAG, "searched device %s\n", remote_device_name);
                    if (conn == false) {
                        conn = true;
                        ESP_LOGI(GATTC_TAG, "connect to the remote device.");
                        esp_ble_gap_stop_scanning();
                        esp_ble_gattc_open(gl_profile_tab[PROFILE_A_APP_ID].gattc_if, scan_result->scan_rst.bda, scan_result->scan_rst.ble_addr_type, true);
        case ESP_GAP_SEARCH_INQ_CMPL_EVT:
        default:
    case ESP_GAP_BLE_SCAN_STOP_COMPLETE_EVT:
        if (param->scan_stop_cmpl.status != ESP_BT_STATUS_SUCCESS){
            ESP_LOGE(GATTC_TAG, "scan stop failed, error status = %x", param->scan_stop_cmpl.status);
        ESP_LOGI(GATTC_TAG, "stop scan successfully");
    case ESP_GAP_BLE_ADV_STOP_COMPLETE_EVT:
        if (param->adv_stop_cmpl.status != ESP_BT_STATUS_SUCCESS){
            ESP_LOGE(GATTC_TAG, "adv stop failed, error status = %x", param->adv_stop_cmpl.status);
        ESP_LOGI(GATTC_TAG, "stop adv successfully");
    case ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT:
         ESP_LOGI(GATTC_TAG, "update connection params status = %d, min_int = %d, max_int = %d,conn_int = %d,latency = %d, timeout = %d",
                  param->update_conn_params.status,
                  param->update_conn_params.min_int,
                  param->update_conn_params.max_int,
                  param->update_conn_params.conn_int,
                  param->update_conn_params.latency,
                  param->update_conn_params.timeout);
    default:
    /* If event is register event, store the gattc_if for each profile */
    if (event == ESP_GATTC_REG_EVT) {
        if (param->reg.status == ESP_GATT_OK) {
            gl_profile_tab[param->reg.app_id].gattc_if = gattc_if;
            ESP_LOGI(GATTC_TAG, "reg app failed, app_id %04x, status %d",
                    param->reg.app_id,
                    param->reg.status);
            return;
    /* If the gattc_if equal to profile A, call profile A cb handler,
     * so here call each profile's callback */
    do {
        int idx;
        for (idx = 0; idx < PROFILE_NUM; idx++) {
            if (gattc_if == ESP_GATT_IF_NONE || /* ESP_GATT_IF_NONE, not specify a certain gatt_if, need to call every profile cb function */
                    gattc_if == gl_profile_tab[idx].gattc_if) {
                if (gl_profile_tab[idx].gattc_cb) {
                    gl_profile_tab[idx].gattc_cb(event, gattc_if, param);
    } while (0);
void app_main()
    ESP_LOGI("Startup", "[APP] Startup..");
    ESP_LOGI("Startup", "[APP] Free memory: %d bytes", esp_get_free_heap_size());
    ESP_LOGI("Startup", "[APP] IDF version: %s", esp_get_idf_version());
    esp_log_level_set("*", ESP_LOG_INFO);
    esp_log_level_set("MQTT_CLIENT", ESP_LOG_VERBOSE);
    esp_log_level_set("TRANSPORT_TCP", ESP_LOG_VERBOSE);
    esp_log_level_set("TRANSPORT_SSL", ESP_LOG_VERBOSE);
    esp_log_level_set("TRANSPORT", ESP_LOG_VERBOSE);
    esp_log_level_set("OUTBOX", ESP_LOG_VERBOSE);
    // Initialize NVS.
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
    ESP_ERROR_CHECK( ret );
    // Wifi section
    wifi_init();
    // End Wifi section
    //mqtt start function
    mqtt_app_start();
    ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT));
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    ret = esp_bt_controller_init(&bt_cfg);
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s initialize controller failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bt_controller_enable(ESP_BT_MODE_BLE);
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s enable controller failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bluedroid_init();
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s init bluetooth failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bluedroid_enable();
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s enable bluetooth failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    //register the  callback function to the gap module
    ret = esp_ble_gap_register_callback(esp_gap_cb);
    if (ret){
        ESP_LOGE(GATTC_TAG, "%s gap register failed, error code = %x\n", __func__, ret);
        return;
    //register the callback function to the gattc module
    ret = esp_ble_gattc_register_callback(esp_gattc_cb);
    if(ret){
        ESP_LOGE(GATTC_TAG, "%s gattc register failed, error code = %x\n", __func__, ret);
        return;
    ret = esp_ble_gattc_app_register(PROFILE_A_APP_ID);
    if (ret){
        ESP_LOGE(GATTC_TAG, "%s gattc app register failed, error code = %x\n", __func__, ret);
    esp_err_t local_mtu_ret = esp_ble_gatt_set_local_mtu(500);
    if (local_mtu_ret){
        ESP_LOGE(GATTC_TAG, "set local  MTU failed, error code = %x", local_mtu_ret);
chegewara
Re: BT: bta_gattc_co_cache_addr_init, Line = 333, nvs flash get blob data fail, err_code = 110c
Postby chegewara » Thu May 24, 2018 4:23 am
With mqtt code commented out(i dont have it) all works fine.
* data.
#endif
#endif
#endif
#include <stdint.h>
#include <string.h>
#include <stdio.h>
#include "nvs.h"
//#include "controller.h"
#include "esp_bt.h"
//Wifi Section
//#include "mqtt_client.h"
            esp_wifi_connect();
            esp_wifi_connect();
        default:
    return ESP_OK;
        .sta = {
            .ssid = "Laptop", //borch
            .password = "12345678", //borch
//End Wifi Section
    int msg_id;
    return ESP_OK;
"b+jcOvfgFW8=\n"\
"do0=\n"\
// end mqtt section
//Wifi Section
//End Wifi Section
    .scan_window            = 0x30
    uint16_t gattc_if;
    uint16_t app_id;
    uint16_t conn_id;
    switch (event) {
        if (scan_ret){
        if (mtu_ret){
            get_server = true;
        if (get_server){
            uint16_t count = 0;
        INVALID_HANDLE,
        &count);
            if (count > 0){
                }else{
                                                             char_elem_result,
                                                             &count);
            }else{
        }else{
            uint16_t count = 0;
        &count);
            if (count > 0){
                }else{
        notify_descr_uuid,
        descr_elem_result,
        &count);
        sizeof(notify_en),
            else{
        }else{
                                  write_char_data,
        esp_bd_addr_t bda;
        conn = false;
        get_server = false;
    default:
    switch (event) {
                int i,j;
                    else
                        j--;
                        conn = true;
        default:
    default:
                    param->reg.app_id,
                    param->reg.status);
            return;
    do {
        int idx;
    } while (0);
void app_main()
 //   esp_log_level_set("MQTT_CLIENT", ESP_LOG_VERBOSE);
    // Initialize NVS.
    // Wifi section
    wifi_init();
    // End Wifi section
 //   mqtt_app_start();
    if (ret) {
        return;
    if (ret) {
        return;
    if (ret) {
        return;
    if (ret) {
        return;
    if (ret){
        return;
    if(ret){
        return;
    if (ret){
    if (local_mtu_ret){
Also try to use this line as very first line in app_main:
Users browsing this forum: Bing [Bot], ChatGPT-User, Semrush [Bot] and 0 guests
