Hi Gents,
I would like to know if someone can respond my questions about HSPI in the slave mode using DMA. If someone know the response I am appreciated if share the answer with me also.
Questions are :
1. If I want to use the original alternative pins for Slave SPI, is the following pin initialization is correct?
//CLK
gpio_pad_select_gpio(GPIO_NUM_14);
gpio_set_direction(GPIO_NUM_14, GPIO_MODE_INPUT);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTMS_U, 1); //gpio_matrix_in(GPIO_NUM_14, HSPICLK_IN_IDX,0);
//MISO
gpio_pad_select_gpio(GPIO_NUM_12);
gpio_set_direction(GPIO_NUM_12, GPIO_MODE_OUTPUT);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U, 1); //gpio_matrix_out(GPIO_NUM_12, HSPIQ_OUT_IDX,0,0);
//MOSI
gpio_pad_select_gpio(GPIO_NUM_13);
gpio_set_direction(GPIO_NUM_13, GPIO_MODE_INPUT);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, 1); //gpio_matrix_in(GPIO_NUM_13, HSPID_IN_IDX,0);
//CSS
gpio_pad_select_gpio(GPIO_NUM_15);
gpio_set_direction(GPIO_NUM_15, GPIO_MODE_INPUT);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, 1); //gpio_matrix_in(GPIO_NUM_15, HSPICS0_IN_IDX,0);
2. When data is being sent by Host MCU (which is set in SPI master mode) the ESP32 doesn't assert the DMA_ISR! Do you guys know if ESP32's SPI slave mode with DMA needs any special command/address in the beginning or it can work completely transparent (just pure data) without any command and address?
3. For SPI in the slave or master mode should I use special channel of DMA or any of existed channels could be workable?
Thanks in advance~~
Mehrdad F.
ESP32 SPI pin initialization in the slave mode,
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
- All times are UTC
- Top
- Delete cookies
About Us
Information
