If want to enable WiFi and BLE with partitions two ota, 4MB flash is enough or not?
Hi All,
I'm newer with ESP32, I want to use ESP32 to build a gateway for BLE devices. I build a very simple application with WiFi and BLE,
and found the flash already over 1MB. and the RAM remain about 60KB.
If enable two partitions OTA, is 4MB flash enough? How to customize the partition table. Thanks.
Re: If want to enable WiFi and BLE with partitions two ota, 4MB flash is enough or not?
Howdy and welcome to the forum.
This is a good document on using the partition tables:
http://esp-idf.readthedocs.io/en/latest ... ables.html
and this for OTA updates:
http://esp-idf.readthedocs.io/en/latest ... m/ota.html
maybe have a read of these documents and see if they help. If not, have a search in this forum and see if there is more light and if that doesn't help or you still have questions, then if nothing else you'll have more details background.
I've run into a similar situation. I'm using WiFi, SmartConfig, BLE, AWS IoT, Shadow data, OTA, and a few other things. My application is sitting at about 1.1 MB. I've eliminated the factory partition and upped my two OTA partitions to 1.5 MB each. Once the system leaves the factory, we do not want the factory application to ever run again. So I figure we don't need the factory partition when we can load it into ota_0, configure and test the device, then let it update using ota_1. The factory partition seems like wasted space to me in many use cases.
nvs, data, nvs, 0x9000, 0x6000,
otadata, data, ota, , 0x2000,
phy_init, data, phy, , 0x1000,
certs, data, spiffs, , 0x10000,
fact_cfg, data, spiffs, , 0x8000,
user_cfg, data, spiffs, , 0x8000,
storage, data, spiffs, , 0x10000,
ota_0, app, ota_0, 0x100000,0x180000,
ota_1, app, ota_1, , 0x180000,
# factory, app, factory, 0x100000,1M,
# ota_0, app, ota_0, , 1M,
# ota_1, app, ota_1, , 1M
When changing the partition table memory values, are there certain rules to be careful about - like size limits, how sizes add up, using certain multiples, and so forth? Must the board.txt values match the default.csv values?
I've just started working on a Wemos (knockoff) ESP32 with OLED, using Arduino 1.8.5 with default settings, selecting the Wemos Lolin32 board. It worked fine with just BLE. But when I added Wifi, it ran out of memory.
Then I edited ../espressif/ESP32/board.txt like this:
I also changed the default partition to:
Now the compile works, and the program executes, but it also stops right away with the Serial.print message "user code done".
Any idea what I'm messing up?
lolin32.name=WEMOS LOLIN32
lolin32.upload.tool=esptool
lolin32.upload.maximum_size=1810720
lolin32.upload.maximum_data_size=494912
lolin32.upload.wait_for_upload_port=true
lolin32.serial.disableDTR=true
lolin32.serial.disableRTS=true
lolin32.build.mcu=esp32
lolin32.build.core=esp32
lolin32.build.variant=lolin32
lolin32.build.board=LOLIN32
lolin32.build.f_cpu=240000000L
lolin32.build.flash_mode=dio
lolin32.build.flash_size=4MB
lolin32.build.boot=dio
lolin32.build.partitions=default
lolin32.menu.FlashFreq.80=80MHz
lolin32.menu.FlashFreq.80.build.flash_freq=80m
lolin32.menu.FlashFreq.40=40MHz
lolin32.menu.FlashFreq.40.build.flash_freq=40m
lolin32.menu.PartitionScheme.default=Default
lolin32.menu.PartitionScheme.default.build.partitions=default
lolin32.menu.PartitionScheme.no_ota=No OTA (Large APP)
lolin32.menu.PartitionScheme.no_ota.build.partitions=no_ota
lolin32.menu.PartitionScheme.no_ota.upload.maximum_size=2097152
lolin32.menu.PartitionScheme.min_spiffs=Minimal SPIFFS (Large APPS with OTA)
lolin32.menu.PartitionScheme.min_spiffs.build.partitions=min_spiffs
lolin32.menu.PartitionScheme.min_spiffs.upload.maximum_size=2966080
# Espressif ESP32 Partition Table
nvs,data,nvs,0x9000,20K,
otadata,data,ota,0xe000,8K,
app0,app,ota_0,0x10000,1280K,
app1,app,ota_1,0x150000,1280K,
eeprom,data,153,0x290000,4K,
spiffs,data,spiffs,0x291000,1468K,
hi,
i have a doubt that, the ESP32 are able to work in APSTA mode along with BLE.? if you have any link regarding this please share with me
What makes you doubt that? As usual with WiFi/BL coexistence, performance will be impacted (depending on what you try to do) but to my knowledge there's no reason it won't work.
Good news! I found the right partition table combination to get BLE, WiFi and the integrated OLED all working together! I'm so happy.
(I'll post those partition settings later. I'm at work, and they're on my home computer.)
It seems you're flashing your program to some addres that has no code.RBruderick wrote:When changing the partition table memory values, are there certain rules to be careful about - like size limits, how sizes add up, using certain multiples, and so forth? Must the board.txt values match the default.csv values?
I also changed the default partition to:Code: Select all
lolin32.name=WEMOS LOLIN32 lolin32.upload.tool=esptool lolin32.upload.maximum_size=1810720 lolin32.upload.maximum_data_size=494912 lolin32.upload.wait_for_upload_port=true lolin32.serial.disableDTR=true lolin32.serial.disableRTS=true lolin32.build.mcu=esp32 lolin32.build.core=esp32 lolin32.build.variant=lolin32 lolin32.build.board=LOLIN32 lolin32.build.f_cpu=240000000L lolin32.build.flash_mode=dio lolin32.build.flash_size=4MB lolin32.build.boot=dio lolin32.build.partitions=default lolin32.menu.FlashFreq.80=80MHz lolin32.menu.FlashFreq.80.build.flash_freq=80m lolin32.menu.FlashFreq.40=40MHz lolin32.menu.FlashFreq.40.build.flash_freq=40m lolin32.menu.PartitionScheme.default=Default lolin32.menu.PartitionScheme.default.build.partitions=default lolin32.menu.PartitionScheme.no_ota=No OTA (Large APP) lolin32.menu.PartitionScheme.no_ota.build.partitions=no_ota lolin32.menu.PartitionScheme.no_ota.upload.maximum_size=2097152 lolin32.menu.PartitionScheme.min_spiffs=Minimal SPIFFS (Large APPS with OTA) lolin32.menu.PartitionScheme.min_spiffs.build.partitions=min_spiffs lolin32.menu.PartitionScheme.min_spiffs.upload.maximum_size=2966080
Now the compile works, and the program executes, but it also stops right away with the Serial.print message "user code done".Code: Select all
# Espressif ESP32 Partition Table # Name, Type, SubType, Offset, Size, Flags nvs,data,nvs,0x9000,20K, otadata,data,ota,0xe000,8K, app0,app,ota_0,0x10000,1280K, app1,app,ota_1,0x150000,1280K, eeprom,data,153,0x290000,4K, spiffs,data,spiffs,0x291000,1468K,
You have to go to 'menuconfig->Partition Table' and modify 'Factory app partition offset' and set as same as your partition, in your case '0x10000'.
Hi everybody,
A question for RBruderick, You did not post the right partition table combination to get BLE, WiFi.
Could You share it?,
Actually I run my scketch with wifi and ble, but without ota and the ble doesn't work very well
Thank You.
Best Regards
Marco
Thank You.
Best Regards
Marco
Hey, Marco.
Sorry about that! Here are my changes that are working well for me:
* Edit ../esp32/boards.txt, find your board (WEMOS LOLIN32), and set:
* lolin32.upload.maximum_size=1810720
* lolin32.upload.maximum_data_size=394912
* Then edit the Partition Table: default.CSV
* # Espressif ESP32 Partition Table
* # Name, Type, SubType, Offset, Size, Flags
* nvs ,data, nvs, 0x9000, 24K,
* phy_init, data, phy, 0xf000, 4K,
* factory, app, factory, 0x10000, 3M,
Users browsing this forum: Bing [Bot], MicroController and 89 guests
