Hello all,
we would like to use cmsis-rtos to interface with freertos
For every XXX() api freertos has also the XXXFromISR() version: so we need to know if there is an intrinsic that tell us if we are inside an interrupt handler, something like __get_IPSR() for cortex processors
Thank you
Max
cmsis-rtos
Re: cmsis-rtos
__asm__ ("break 0,0");
should break into debugger if OCD is enabled, and raise DebugException if not.
Re: cmsis-rtos
Thank you ESP_igrr,
now I can complete my macros:
#ifdef NDEBUG
# define CHECK_IT(a) (void)(a)
# define BPOINT
#else
# define CHECK_IT(a) assert(a)
# define BPOINT __asm__("break 0,0")
#endif
Re: cmsis-rtos
By the way is there any support in OpenOCD / gdb to step over break instruction once reached?__asm__ ("break 0,0");
EDIT:
Found https://github.com/espressif/openocd-esp32/issues/2
Users browsing this forum: Bing [Bot], Google [Bot], PerplexityBot, Semrush [Bot] and 1 guest
