Running ESP32 at 2.8V
Posted: Fri Jun 15, 2018 11:49 pm
by p-rimes
Cool part: Microchip Technology MIC5356-MGYML-TR
https://www.digikey.ca/product-detail/e ... ND/5700737
Dual linear voltage regulators @2.8v and @1.8v, 500ma current each, $0.30 (cheaper than my current single 3.3v reg!)
In the interests of power savings, can anyone recommend using (or not using) this part with an ESP32 module? I already have a SMPS 5v supply in the mix, which would be the supply for this reg.
Re: Running ESP32 at 2.8V
Posted: Sat Jun 16, 2018 12:14 am
by WiFive
Will you realize power savings by dropping more voltage across a linear reg?
Posted: Sun Jun 17, 2018 4:02 pm
by p-rimes
Honestly, I'm not sure. I know a bit about linear electronics, and I did expect extra loss on the LDO. But for all that the ESP32 is doing (RF, internal amplifiers, internal voltage domains, etc), I wasn't sure what the pros/cons of a reduced voltage are (if you just treat it as a linear black box/load with 500ma draw, or as something like a diode, then I agree it's probably not a good idea).
I guess I don't have a good mental model for digital circuit design; I'm not really sure what's going on between 3.3V and GND inside an IC (especially without the power curves section on a datasheet). When I hear "non-linear" devices, I guess I thought that could also mean... worse than linear?
What about in the case of an ideal 2.8V source vs. a 3.3V source (not worrying about LDO), any reason to run at 2.8V (or any other voltage than 3.3V)?
Posted: Sun Jun 17, 2018 6:11 pm
by krzychb
Hi @p-rimes,
Running a chip at reduced voltage means reducing power consumption by the chip.
This is done to e.g. run the chip for a longer time on a battery.
The overall power consumption will not be reduced by dropping the voltage (and dissipating power) on a linear voltage regulator. What will be saved on the chip will be lost on the linear voltage regulator.
Instead I would use a switching regulator.
Check Advantages / Disadvantages under
What is the Difference Between Linear and Switching Regulators?
