Generatig a clock frequency
OneTwo
Postby OneTwo » Thu Jun 21, 2018 9:26 am
Hallo all,
i would like to know if it is possible to generate a constant frequency of 1.024 Mhz (~1Mhz) on a PIN and if so do you have example codes?
Many thanks in advance
WiFive
Re: Generatig a clock frequency
Postby WiFive » Thu Jun 21, 2018 10:24 am
OneTwo
Postby OneTwo » Thu Jun 21, 2018 11:23 am
Because im not an expert at hardware level, could you try to explain the following attributes:
  • ledc_channel_config_t.duty
    ledc_timer_config_t.duty_resolution
Should i use LEDC_APB_CLK_HZ which gives 80MHz or LEDC_REF_CLK_HZ with 1MHz?
For example without tesing:
    periph_module_enable(PERIPH_LEDC_MODULE);
    int bit_width = 8; // idk
    int divider =  80;  // 80MHz / 80 ~ 1MHz
    int duty_cycle = 1 << (bit_width - 1);	// ?? 128
    float freq_hz = ((uint64_t) LEDC_APB_CLK_HZ << 8) / (float) divider / (1 << bit_width);
    printf("frequency: %f Hz\n", freq_hz);
    ledc_timer_set(LEDC_HIGH_SPEED_MODE, LEDC_TIMER_0, divider, bit_width, LEDC_APB_CLK_HZ );
    ledc_timer_rst(LEDC_HIGH_SPEED_MODE, LEDC_TIMER_0);
    ledc_timer_resume(LEDC_HIGH_SPEED_MODE, LEDC_TIMER_0);
    ledc_channel_config_t channel_config = {
        .channel    = LEDC_CHANNEL_0,
        .duty       = duty_cycle,
        .gpio_num   = GPIO_NUM_2,
        .speed_mode = LEDC_HIGH_SPEED_MODE,
        .timer_sel  = LEDC_TIMER_0
    ledc_channel_config(&channel_config);
igrr
Postby igrr » Thu Jun 21, 2018 1:26 pm
Divider has 8-bit fractional part, so you probably need to set it to 80MHz/1.024MHz*256=20000.
Bit_num=8 and duty=127 seems to be okay, should generate 50% duty cycle.
OneTwo
Postby OneTwo » Mon Jun 25, 2018 11:07 am
Thank you, i solved that with the following code:
	int bit_width = 1; // 1 - 20 bits
	int divider = 10240;  // Q10.8 fixed point number, 0x100 — 0x3FFFF
	ledc_timer_set(LEDC_HIGH_SPEED_MODE, LEDC_TIMER_0, divider, bit_width, LEDC_APB_CLK);
	ledc_channel_config_t channel_config = {0};
	channel_config.channel    = LEDC_CHANNEL_0;
	channel_config.duty       = duty_cycle;
	channel_config.gpio_num   = PIN_CLOCK;
	channel_config.speed_mode = LEDC_HIGH_SPEED_MODE;
	channel_config.timer_sel  = LEDC_TIMER_0;
Users browsing this forum: Baidu [Spider], Qwantbot and 2 guests
