OpenOCD for ESP32-devkit-C with FT232HL on macOS
y-hira
Postby y-hira » Thu Jun 21, 2018 10:19 am
Hi, I am trying to use JTAG debugging on macOS 10.13.3.
I tried:
http://esp-idf.readthedocs.io/en/latest ... index.html
I made this file
ft232hl.cfg:
interface ftdi
ftdi_vid_pid 0x0403 0x6014
ftdi_channel 0
reset_config none
adapter_khz 20000
transport select jtag
I connected FT232HL adapter to MacBook, and can see vid: 0x0403, pid: 0x6014 device on System Information.app.
Then
$ openocd -f ft232hl.cfg -f target/esp32.cfg
Open On-Chip Debugger 0.10.0-dev-00003-ga9ec3301 (2018-06-07-17:20)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
jtag
esp32 interrupt mask on
force hard breakpoints
Error: libusb_claim_interface() failed with LIBUSB_ERROR_ACCESS
Error: unable to open ftdi device with vid 0403, pid 6014, description '*', serial '*' at bus location '*'
and I tried:
~ sudo kextunload -p -b com.apple.driver.AppleUSBFTDI
~ sudo kextutil -b com.apple.driver.AppleUSBFTDI -p AppleUSBEFTDI-6010-1
and connected FT232HL again, but nothing changed.
How can I use OpenOCD for ESP32-devkit-C with FT232HL on macOS?
w19787
Re: OpenOCD for ESP32-devkit-C with FT232HL on macOS
Postby w19787 » Mon Jul 02, 2018 3:21 am
please try:
sudo kextunload -bundle-id com.FTDI.driver.FTDIUSBSerialDriver
but this is a negative impact, the uart channel has been closed as well. i don't have solution for this yet.
y-hira
Postby y-hira » Wed Oct 03, 2018 7:44 am
Thank you very much!
Users browsing this forum: No registered users and 165 guests
