Hello all,
I have an issue with Eclipse.
Everything was working fine but building time was a little bit slow. Quite normal under windows 10 and MSYS32.
For other reasons i tried activating WSL on windows. Since that moment, building under Eclipse didn't work. So i disabled WSL and now building works again. I did many things so not 100% sure it was the problem.
Problem is, it's now extremly slow. I tried building the helloworld through Eclipse and i'm at 11 minutes and it still at 31% !!
If i do this in MSYS32, i build in approx 1 minute and a half with a -j4. Still a long time for a simple example but this is consistent with what i had before in eclipse.
Any idea how i could have messed up my Eclipse build time ? and what i should do to correct this?
Extremely slwo build time in eclipse (not in MSYS)
Re: Extremely slwo build time in eclipse (not in MSYS)
If i run the python script in MSYS32, i also have a very long build time (more than hour).
So this is not related to eclipse.
Any idea?
Any idea?
I had a similar issue in the past and it was caused by an antivirus/antimalware intensively checking files created during compilation.
Try disabling any antivirus/antimalware software or create an exception on the compilation folder.
FYI these are the instructions I use on MS WIndows developer machines to speedup the make:
### IMPROVE MAKE's PERFORMANCE*** WINDOWS DEFENDER: DISABLE CHECKING THE MSYS2 FOLDER and MYIOT FOLDER
Windows Defender => Virus & Thread Protection => Virus & Thread protection settings => Exclusions:
EXCLUDE DIR c:\msys32\
EXCLUDE DIR c:\myiot\
### PROBLEM FIXING FIX for error ""error: cannot fork() for fetch-pack: Resource temporarily unavailable"" when doing Git push issues
#GITCMD>
\msys32\autorebase.bat
Paul.
Paul.
tangqingcai
mark;
Does anyone have resolved this problem?
Disable windows Defender from scanning your dev directory. (i.e. the build directory creates tons of files to scan). When using make, you can specify how many threads with -j option. So if you have a quad core w/ 2 threads per core then use 8.
make -j8
John A
make -j8
John A
I am using CMake IDF and average fresh compilation of very large project takes no longer than 10s and less than 20s with flashing.
It is like 2-3s after first compilation
We should all switch to CMake
Users browsing this forum: Amazon [Bot], Bytespider, ChatGPT-User, coccocbot, Google [Bot], Semrush [Bot] and 1 guest
