I'm trying to update via a Webinterface the SSID, Password, Port, etc. on my ESP32.
For that I've written a class, to handle everything which depends on WiFi. When I try to update a variable, I get the error:
Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x4000169e PS : 0x00060330 A0 : 0x800da3a1 A1 : 0x3ffbf650
A2 : 0x00000021 A3 : 0x3ffaf219 A4 : 0x0000000b A5 : 0x0000ff00
A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x00000064 A9 : 0x3ffbf620
A10 : 0x00000021 A11 : 0x000000ff A12 : 0x000000ff A13 : 0x0000ff00
A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x0000000a EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000021 LBEG : 0x40001699 LEND : 0x400016aa LCOUNT : 0xffffffff
Backtrace: 0x4000169e:0x3ffbf650 0x400da39e:0x3ffbf660 0x400d9699:0x3ffbf680 0x400d98da:0x3ffbf6b0 0x400d1f8b:0x3ffbf6d0 0x400d56f1:0x3ffbf7
10 0x400d576d:0x3ffbf760 0x4012d681:0x3ffbf780 0x4012d8ad:0x3ffbf7d0
Rebooting...My Code is the following:
Credentials.h:
#ifndef __CREDENTIALS_H__
#define __CREDENTIALS_H__
#include <Arduino.h>
struct Credentials{
char ssid[33];
char password[65];
char name[33];
int port;
#endif
#ifndef __CREDENTIALSSTRUCT_H__
#define __CREDENTIALSSTRUCT_H__
#include "Arduino.h"
#include "WiFi.h"
#include "ESPmDNS.h"
#include "ESPAsyncWebServer.h"
#include "Credentials.h"
class WiFiConfig {
public:
WiFiConfig(Credentials &, AsyncWebServer &);
bool changeSSID(AsyncWebServerRequest *request);
bool setCONFIGMode();
private:
struct Credentials* _configs;
AsyncWebServer* _webServer;
#endif
#include "WiFiConfig.h"
WiFiConfig::WiFiConfig(Credentials &configs, AsyncWebServer &webServer) : _configs(&configs), _webServer(&webServer)
bool WiFiConfig::changeSSID(AsyncWebServerRequest *request)
AsyncWebParameter* param = request->getParam("ssid_input",true);
param->value().toCharArray(_configs->ssid,sizeof(_configs->ssid)); //This line causes the failure
Serial.println(_configs->ssid);
return true;
bool WiFiConfig::setCONFIGMode()
IPAddress apIP(192, 168, 1, 1);
IPAddress &gateway = apIP;
IPAddress subnet(255,255,255,0);
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(apIP, gateway, subnet);
WiFi.softAP(_configs->ssid, _configs->password);
WiFi.setHostname(_configs->name);
if (!MDNS.begin(_configs->name)) {
Serial.println("Error setting up MDNS responder!");
MDNS.addService("http", "tcp", _configs->port);
_webServer->on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->redirect("/config.html");
_webServer->on("/changeSSID", HTTP_POST, [this](AsyncWebServerRequest *request)
this->changeSSID(request);
return true;
Credentials configs = {"SamplePWD", "ExamplePWD", "ExampleMDNS", 80}; //last one is the port
AsyncWebServer webServer(configs.port);
void setup(){
WiFiConfig wifi(configs, webServer);
wifi.setCONFIGMode();
webServer.begin();
void loop() {}
The problem is caused on accessing "_configs->ssid" from a "_webServer->on" function.
Has somebody had a similar error, or knows what I'm doing wrong?
Best,
Terratrembel
