(Noob) Schematic Question
hotsnot101
Postby hotsnot101 » Sun Jul 22, 2018 1:11 pm
Hi everyone!
I've created a breakout board for the ESP-WROOM-32 and I'm trying to figure out if there is something wrong with my (boiled down) schematic:
Screen Shot 2018-07-22 at 9.01.33 PM.png (99.64 KiB) Viewed 1420 times
Is there any reason this schematic would not enable me to have a working breakout board for just programming? I've conducted an open short test on my PCB, and everything looks fine. I've also only soldered these points - so I'm wondering if this is wrong, or maybe I have a bad component.
Thanks!
f.h-f.s.
Re: (Noob) Schematic Question
Postby f.h-f.s. » Mon Jul 23, 2018 11:22 am
Have a look at the DevKitC schematic at https://dl.espressif.com/dl/schematics/ ... V2_sch.pdf
I think the problem is located on your IO0 and EN lines, but that's just a guess. That schematic is a great reference though ;)
Vader_Mester
Contact:
Postby Vader_Mester » Mon Jul 23, 2018 11:49 am
I suggest you implement this circuit (see below pic). This will enable you to use any external UART interface.
Also, please place a 0,1uF capacitor to the EN pin. This can be a 10% regural ceramic cap, 25V, which is used in every dev board.
There were other notations on the forum with some timing issue, that the EN pin must be pulled high later than the IO0. This capacitor does just that. While it charges, it will keep the signal low for long enough, so the proper programming mode to be entered.
I suggest reading this topic. about this issue.
There are 2 types of programmer people: The Expert programmer and The Smart programmer
The Expert programmer easily writes any code from scratch.
The Smart programmer uses his google/github powers first ;)
Users browsing this forum: No registered users and 50 guests
