ESP32 FAT_DATE dos not work...
Posted: Thu Aug 09, 2018 11:26 pm
by Pcborges
Hi, I am porting a project that runs on a Mega256 where I use the following code to inform the SD routine to add date creation/update properly:
The code below does not work with ESP32's SD.h
What should I use to provide the SD files with time stamps?
Assistance welcome.
Paulo
//function to supply datetime to SD file system
void dateTime(uint16_t* date, uint16_t* time)
// return date using FAT_DATE macro to format fields
*date = FAT_DATE(Clock.getYear() - 48, Clock.getMonth(Century), Clock.getDate());
// return time using FAT_TIME macro to format fields
*time = FAT_TIME(Clock.getHour(h12, PM), Clock.getMinute(), Clock.getSecond());
Compilation time error:
exit status 1
'FAT_DATE' was not declared in this scope
Re: ESP32 FAT_DATE dos not work...
Posted: Wed Jun 11, 2025 2:02 pm
by codingj
Dear Team,
I've also same trouble and no solution seems available actually...
Thanks.
Posted: Wed Jun 25, 2025 4:10 pm
by lbernstone
The FS library does automatically set the file access times when writing a file to SD and has a method to access that.
If you want more arbitrary access to the file stat info, you can use POSIX functions like utime.
