esp_partition_mmap is not decrypting partition data?
dmitryga
Postby dmitryga » Wed Aug 15, 2018 4:39 pm
Hi everybody!
I'm using flash encryption and try to access encrypted partition.
First of all I've created data partition with size 0x1000 (4KB) and encrypted flag.
Secondly I've allocated 4KB buffer, filled it with 0xFF and set contents of first 48 bytes to some known values (to check them later). These bytes were:
00 00 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d
3e 3f 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d
4e 4f 00 f8 60 5b 80 d2 b8 5d 00 00 c0 13 c3 1f
Thirdly I've written this buffer using esp_partition_erase_range and esp_partition_write. Both calls succeeded.
Now I'm trying to read partition using esp_partition_read. This call also succeeds, but contents of buffer seems to be still encrypted. First 128 bytes looks like this:
5f 8a b7 cb 16 9d 1f 40 cc c0 34 76 c4 ba 3d bf
5c ce 81 53 ba 02 dc ba be de b7 14 80 44 94 03
55 ed 28 a4 fd d1 0f 55 d5 3a c5 d2 2a cb ed bf
fb df 3e 4d ac 5e 64 b3 10 77 53 7c 46 a9 9f 12
In esp-idf sources I see, that esp_partition_write internally calls spi_flash_write_encrypted for encrypted partitions, but esp_partition_read calls esp_partition_mmap, which should transparently decrypt data during memory mapping. But as we see, either esp_partition_mmap is not decrypting, either spi_flash_write_encrypted is not encrypting...
Or maybe I'm doing something wrong?
dmitryga
Re: esp_partition_mmap is not decrypting partition data or spi_flash_write_encrypted is not encrypting?
Postby dmitryga » Wed Aug 15, 2018 4:45 pm
I've used esptool.py to dump partition contents. They are equal to buffer contents I see after esp_partition_read call. So it seems that esp_partition_mmap is not decrypting my partition...
WiFive
Re: esp_partition_mmap is not decrypting partition data?
Postby WiFive » Wed Aug 15, 2018 9:25 pm
Did you enable flash encryption or just set encrypted flag in partition table?
dmitryga
Postby dmitryga » Thu Aug 16, 2018 7:43 am
WiFive, you're right!
I was carrying my experiments on ESP where flash encryption was not enabled, but partition mentioned had had encrypted flag set. I examined source code of esp_partition_write and saw that it checks encrypted flag but does not check, whether encryption is globally enabled.
Users browsing this forum: No registered users and 192 guests
