SPIFFS: spiffs partition could not be found
sheikhumar93
Postby sheikhumar93 » Wed Aug 15, 2018 5:47 pm
My spiffs code taken from the example was running absolutely fine until I ran
make erase_flash partition_table flash monitor
and now when I run my code again it says :
E (16826) SPIFFS: spiffs partition could not be found
E (16831) Example: Failed to find SPIFFS partition
format_if_mount_failed=true is supposed to fix this issue but it is not working.
ESP_LOGI(TAG, "Initializing SPIFFS");
esp_vfs_spiffs_conf_t conf = {
        .base_path = "/spiffs",
        .partition_label = NULL,
        .max_files = 5,
        .format_if_mount_failed = true
// Use settings defined above to initialize and mount SPIFFS filesystem.
// Note: esp_vfs_spiffs_register is an all-in-one convenience function.
esp_err_t ret = esp_vfs_spiffs_register(&conf);
if (ret != ESP_OK) {
    if (ret == ESP_FAIL) {
        ESP_LOGE(TAG, "Failed to mount or format filesystem");
    } else if (ret == ESP_ERR_NOT_FOUND) {
        ESP_LOGE(TAG, "Failed to find SPIFFS partition");
        ESP_LOGE(TAG, "Failed to initialize SPIFFS (%s)", esp_err_to_name(ret));
    return;
The log is:
I (4) cpu_start: Starting scheduler on APP CPU.
D (199) heap_init: New heap initialised at 0x3ffe0440
D (205) heap_init: New heap initialised at 0x3ffe4350
D (210) intr_alloc: Connected src 16 to int 12 (cpu 0)
I (215) Example: Initializing SPIFFS
E (220) SPIFFS: spiffs partition could not be found
E (225) Example: Failed to find SPIFFS partition
What should I do to solve this?
sheikhumar93
Re: SPIFFS: spiffs partition could not be found
Postby sheikhumar93 » Thu Aug 16, 2018 5:33 am
yalmog
Postby yalmog » Sat Jun 04, 2022 6:40 pm
I solved it this way:
used "idf.py menuconfig" to change partition table to csv.
created "partitions.csv" with 256KB of spiffs as "/storage":
nvs, data, nvs, 0x9000, 0x6000
phy_init, data, phy, 0xf000, 0x1000
factory, app, factory, 0x10000, 0x100000
storage, data, spiffs, 0x110000, 0x40000
python ..\..\components\partition_table\gen_esp32part.py .\partitions.csv .\partitions.bin
idf.py partition-table-flash
created a folder with my file ./my_spiffs/*.html
python ..\..\components\spiffs\spiffsgen.py 0x40000 .\my_spiffs my_spiffs_img
python ..\..\components\partition_table\parttool.py -p COM3 write_partition --partition-name storage --input .\my_spiffs_img
in code: base_path = "/storage"
Users browsing this forum: ChatGPT-User and 4 guests
