Weird WiFi disconnect issues
jdwix615
Postby jdwix615 » Sat Aug 18, 2018 2:58 am
I have a few boards all with ESP32 WROOM modules on them. There is a weird issue I'm noticing with one of the chips, it seems that it is unable to connect to any SoftAPs created by the other modules. It can however connect to a normal wifi access point and the other modules can connect to this particular module's SoftAP.
The disconnect is coming back with reason code 201 (No AP found) which is odd and doesn't make any sense.
Does anyone have an explanation for the behaviour I'm seeing? Keep in mind that all these modules are loaded with the identical binary.
Thanks.
