Cannot run app on ESP32 from an external battery
Posted: Sun Aug 19, 2018 7:32 pm
by sheikhumar93
I am trying to run an ESP-IDF app on my ESP32 that sends sensor readings to a web server on my Ubuntu machine, I have attached it to 2 batteries and pins to Vin and Gnd with 3.40V. When I connect the ESP32 to a USB port on my PC, it transmits data just fine to my server. But when I connect it to the batteries it does not transmit any data. Both the ESP32 and the MPU6050's onboard LED power up though. What am I doing wrong here?
Re: Cannot run app on ESP32 from an external battery
Posted: Mon Aug 20, 2018 3:16 am
by kolban
If it were me, I'd attach an external UART->USB connector to the RX and TX pins of the ESP32 and see what the console is saying during boot.
Posted: Mon Aug 20, 2018 7:43 am
by Angus
Which pins on the development board are you connecting the 3.4V out of the battery to?
Posted: Mon Aug 20, 2018 8:02 am
by sheikhumar93
To the VIN and GND pins.
@kolban thanks for the reply, unfortunately I don't have access to a USB->UART connector right now.
Posted: Mon Aug 20, 2018 2:09 pm
by loboris
Vin is the LDO input (+5V pin from USB). If the battery voltage is 3.4V, it is probably not enough to give 3.3V on LDO's output (pin 3V3).
You could use the LiFePO4 battery connected directly to 3V3 pin to power the board.
Posted: Sun Aug 26, 2018 12:07 pm
by sheikhumar93
Hi @loboris, if I connect my 3.4V connection to 3v3, where do I connect my I2C sensor's VCC then?
Posted: Sun Aug 26, 2018 1:29 pm
by loboris
It the sensors can be powered from 3.4V, connect them to 3.4V, if thay require some other voltage, you must use separate LDO to power them and some level shifter. Most of the I2C sensors should work with 3.4V.
Be carefull if using Li-Po batteries, fully charged they can have voltage too high for ESP32.
