deep sleep current after wifi stop
I tried to run a simple wifi program, init wifi ->then connect to router->wifi stop->deep sleep, the deep sleep current is around 1.x mA. However, if I don't run the wifi procedure, just start and then deep sleep, the current is around 5.x uA, is it normal? any procedure missing on the wifi routine b4 entering deep sleep mode?
Re: deep sleep current after wifi stop
I have this problem too after using Bluetooth. Current is slightly above 1mA when BT was used and well below if not.
Did you ever find a solution for this?
Users browsing this forum: Amazon [Bot], ChatGPT-User and 3 guests
