Documentation for ESP WROVER KIT 4.1
jcsbanks
Postby jcsbanks » Tue Aug 21, 2018 6:36 pm
Is there any documentation for the above?
Particularly looking for any info on the LCD: https://github.com/loboris/ESP32_TFT_library with ESP WROVER KIT preconfig settings doesn't show anything but a white screen even with DIO and 40MHz SPI speed and PSRAM disabled.
The application it arrived with just outputted "debug", flashed the LED on the back, a quarter of the screen had monochrome lines and the other three quarters had colour.
jcsbanks
Re: Documentation for ESP WROVER KIT 4.1
Postby jcsbanks » Tue Aug 21, 2018 6:50 pm
jcsbanks
Postby jcsbanks » Tue Aug 21, 2018 7:01 pm
// ** Set the correct configuration for ESP32-WROVER-KIT v4.1
#define DEFAULT_DISP_TYPE           DISP_TYPE_ILI9341
#define DEFAULT_TFT_DISPLAY_WIDTH   240
#define DEFAULT_TFT_DISPLAY_HEIGHT  320
#define DISP_COLOR_BITS_24          0x66
#define DEFAULT_GAMMA_CURVE         0
#define DEFAULT_SPI_CLOCK           26000000
#define TFT_INVERT_ROTATION         0
#define TFT_INVERT_ROTATION1        0
#define TFT_RGB_BGR                 0x08
Works with PSRAM enabled, flash and PSRAM at 80MHz, QIO.
Dardan
Postby Dardan » Thu Sep 06, 2018 1:02 pm
esp-wrover_kit 4.1
arduiono ide 1.8.2
Used library "WROVER_KIT_LCD.h"
Project "spitftbitmap.ino"
If the SD card is removed, the LCD works normally, if inserted, the screen is white. The Internet does not know the problem :D . Can developers or experienced professionals tell me what the problem is?
VerusLogic
Postby VerusLogic » Sun Nov 25, 2018 5:33 pm
I am seeing this same issue. The SD card initializs successfully but the display is blank. The jpegtest example works but only when the SD card is out.
Mike.
VerusLogic
Postby VerusLogic » Sun Nov 25, 2018 6:04 pm
I found the problem here. The TFT uses GPIO21 for the DC pin. The SD card uses GPIO21 for the CD pin. If you remove R167 - which is at the bottom left corner of the WROVER module - it will disconnect GPIO21 from the SD card detect line and allow the LCD interface to function.
Mike.
krzychb
Contact:
Postby krzychb » Sat Dec 01, 2018 6:33 pm
Hi Mike,
Nice tip, thank you for documenting it!
I will include this information in ESP-WROVER-KIT Getting Started Guide.
