SDIO Slave. Sending bug.
Posted: Wed Aug 29, 2018 2:53 pm
by alexey91
Hello.
I've faced some kind of bug i can't understand whet trying to send data from SDIO Slave.
I use 4 bit bus and CLK freq is 400kHz.
As i read from docs, buffer for sending have to be 4-byte alligned and DMA accessable. I create it like that
uint8_t * dataBuf = heap_caps_malloc(600, MALLOC_CAP_DMA | MALLOC_CAP_32BIT);
Then i send to send queue some areas of this allocated buffer.
ret = sdio_slave_send_queue(&(dataBuf[100]), 100, &(dataBuf[100]), 0);
if(ret != ESP_OK) {
	printf("failed to send buf 1, errcode = %d\n", ret);
ret = sdio_slave_send_queue(&(dataBuf[200]), 100, &(dataBuf[200]), 0);
if(ret != ESP_OK) {
	printf("failed to send buf 2, errcode = %d\n", ret);
ret = sdio_slave_send_queue(&(dataBuf[300]), 100, &(dataBuf[300]), 0);
if(ret != ESP_OK) {
	printf("failed to send buf 3, errcode = %d\n", ret);
But if my buffer area crosses with addresses 0x3FFB5A6C - 0x3FFB5ABC, then SDIO Slave driver sends rubbish. While SDIO Host clocks all (100 * 2 + 16) ticks for 100 bytes, but slave sets data for less bytes, and send some zeros. With other buffers driver works fine.
In my case 0x3FFB5A6C is address of dataBuf[200], so second buffer area fails to be sent.
dataBuf[100-199] == 0xC3
dataBuf[200-299] == 0xF0
dataBuf[300-399] == 0xA5
i attached LA file for this case, hope bookmarks will not dissapear.
Moving 100 byte sending interval in allocated buffer i've found area (0x3FFB5A6C - 0x3FFB5ABC), that caused problems. If my send buffer touches this area by any address, sendind will be corrupted.
I also tried that on my second esp32 board with same result.
So, what that can be? Is that problem of DMA or SDIO Slave driver or silicon limitations? Are there some more areas like that?
I also attached sourse file, based on standard exanple, that i used while faced that issue.
Thanks,
alexey.
Re: SDIO Slave. Sending bug.
Posted: Thu Aug 30, 2018 7:32 am
by alexey91
Hello.
A little update for my problem. I tried to send other buffers and found, that this sending bug affected by content of buffer, not by addres. If my buffer filled with bytes, where one half of byte == 0xF, and another part have only one set bit or none (i meam bytes: 0x0F, 0x1F, 0x2F, 0x4F, 0x8F, 0xF0, 0xF1, 0xF2, 0xF4 and 0xF8), then SDIO Slave sendind will be corrupted.
So this problem doesnot caused by allocator or DMA access. But anyway i need to know how to understand this to avoid thi failture in my application.
Thanks,
alexey.
Posted: Fri Aug 31, 2018 5:21 am
by michael
Hi alexey,
I think this doesn't make sure all your transactions are done:
while(ESP_ERR_TIMEOUT == sdio_slave_send_get_finished(&tst, 0)){};
The driver needs you to keep the buffer until the sending is finished, so you have to check every one of them is finished or not.
1. To check whether is caused by this issue, you can add a infinite loop (while(1){}) before the free(dataBuf) to avoid touching to the buffer.
2. If the problem is as guessed, suggest to use a counter or something to record whether all your transactions are done. (or you can use the arg parameter to tag the last transaction!) you may set the wait argument to portMAX_DELAY to wait forever.
Please let me know if there's still problems.
Posted: Fri Aug 31, 2018 7:20 am
by alexey91
Hi, xiaoxufeng.
Thanks for reply.
I moved buffer allocation to main, and never free it. And it still failed to send buffer filled with values 0x0F, 0x1F, 0x2F, 0x4F, 0x8F, 0xF0, 0xF1, 0xF2, 0xF4 or 0xF8.
I also tried to make this buffer static,
DMA_ATTR static uint8_t dataBuf[1200];
but that also have no effect. So, this problem caused definitely not by early buffer memory release.
Other thing i found, that sending buffer filled with these values drops some data, here is example.
DMA_ATTR static uint8_t dataBuf[20];
for(i = 0; i < 8; i++) {
    dataBuf[i] = 0x0F;
for(i = 8; i < 20; i++) {
    dataBuf[i] = 0x9F;
ret = sdio_slave_send_queue(dataBuf, 20, dataBuf, 0);
while(1) {};
but sending i see on LA is (i write half bytes by 4 SDIO lines)
  0   1   2   3   4   5   6
0 F 0 F 0 F 0 F 0 F 0 F 0 F 0 9 F 9 F 9 F 9 F 9 F 9 F 9 F 9 F 9 F 9 F 9 F 9 F
This point somehting happened, F is dropped. Host got CRC error
If i change buffer filling with other values, it works ok.
Do you have any ideas, what can it be?
Thanks,
alexey.
