No bootable app partitions with external flash when booting in QIO, but will not build for DIO
jcsbanks
Postby jcsbanks » Mon Sep 03, 2018 2:37 pm
ets Jun  8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 158106054, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:6360
load:0x40078000,len:9884
load:0x40080400,len:6840
entry 0x40080768
I (29) boot: ESP-IDF v3.2-dev-498-g30545f4c-dirty 2nd stage bootloader
I (29) boot: compile time 20:06:41
I (40) boot: Enabling RNG early entropy source...
I (40) qio_mode: Enabling QIO for flash chip WinBond
I (42) boot: SPI Speed      : 80MHz
I (46) boot: SPI Mode       : QIO
I (50) boot: SPI Flash Size : 16MB
I (54) boot: Partition Table:
I (57) boot: ## Label            Usage          Type ST Offset   Length
I (65) boot: End of partition table
E (69) boot: No bootable app partitions in the partition table
However, I know this board will work in DIO, but when I make menuconfig and save the config and flash, it boots as QIO.
Edit: make clean then repeating fixed it. Will leave post up in case anyone else has same problem changing between QIO and DIO.
Angus
Re: No bootable app partitions with external flash when booting in QIO, but will not build for DIO
Postby Angus » Tue Sep 04, 2018 2:02 am
That's quite strange! Where you flashing with "make flash" each time?
If you see this again and have any steps to reproduce the config not changing properly (or not triggering a rebuild), please let us know.
jcsbanks
Postby jcsbanks » Tue Sep 04, 2018 8:13 am
Will do. I had copied the folder to another with a new name for a different PCB with a few changes to pin allocations for hardware.
make -j8 menuconfig
make -j8 flash monitor
